Garage Door Opener Problem - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 05-07-2008, 10:54 PM   #1
I have a Sears opener with 2 remotes and a keypad. I can't open the door with any of them. When I use the keypad the lights on the keypadblinks but does not open. I check the learn button (I believe that's it) and when I press the transmitters the yellow LED next to it blinks as long as I hold down the control. The other door works fine. I heard something about the keypad locking the transmiters or put it in vacation mode??? Any help would be appreciated
rsoukup is offline   Reply With Quote
Old 05-08-2008, 11:25 AM   #2
sestivers's Avatar
Rewards Points: 95
Do you have the manual? It will tell you exactly how to re-program your remotes. If you don't have the manual, you should be able to download it from the Sears website.
Steve
sestivers is offline   Reply With Quote
Old 05-08-2008, 01:48 PM   #3
Nothing about it in the manual I have for the unit. If you or anyone has the prodecures. I have a openers and the other door works fine
Old 05-08-2008, 10:41 PM   #4
I was able to fix the problem. I read some other forums and added to the wire on the unit about 3 inches of bell wire and everything works fine!
Problem with a garage door. ffdanf Building & Construction 5 05-10-2008 11:04 PM
garage door problem nappel General DIY Discussions 8 01-18-2007 04:51 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
Garage door opener problem ffishmonger General DIY Discussions 5 03-28-2006 06:38 PM
garage roof problem ERIK2173 Roofing/Siding 3 11-03-2005 08:44 AM
