Garage Door Opener With A Light Switch? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 08-12-2012, 11:23 AM   #1
Rewards Points: 160
garage door opener with a light switch?
I have an old garage door opener, and the button switch is history...can I just use an extra light switch to activate the door opener?
I know it works, but I'm concerned that if the light switch is on, will it burn out or effect the motor?
hellothere123 is offline   Reply With Quote
Old 08-12-2012, 01:36 PM   #2
oops
Old 08-12-2012, 07:37 PM   #3
Rewards Points: 2,646
I would be looking for a momentary push-button.
Should not be that hard to find.
SPS-1 is offline   Reply With Quote
Old 08-12-2012, 07:43 PM   #4
Rewards Points: 6,652
Door bell button is what is commonly used. Just make sure that you do not use one that has a light in it.
Old 08-12-2012, 07:45 PM   #5
Rewards Points: 14,278
Just use a door bell switch.
And no a light switch will not work, it's a maintained contact switch.
Old 08-13-2012, 10:48 AM   #6
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
Why not?
Old 08-13-2012, 11:59 AM   #7
Because the light causes problems with most openers.
Old 08-13-2012, 05:10 PM   #8
Stuck in the 70's
Thanks for the info.
Ours has used a lighted doorbell for a switch since we had the doors replaced five years ago. No problems so far.
Old 08-14-2012, 11:36 PM   #9
Rewards Points: 160
as long as you leave the light switch to off...the light switch will work...hee hee
Old 08-15-2012, 11:10 AM   #10
How about using a doorbell buttin... They don't stay in the on position once depressed?? Just a thought !
cvbs is offline   Reply With Quote
Light in one lighted three-way switch not working dalepres Electrical 2 06-26-2012 06:27 AM
Replace bathroom light switch with dimmer switch ToddD Electrical 11 05-06-2012 05:58 PM
Hi, new here and have a question about light switch in bathrooms Tazznum1 Electrical 2 01-26-2011 08:31 AM
adding second light from a switch agsurfer Electrical 3 09-10-2010 12:01 PM
Wiring from light to switch and on poorjohn Electrical 3 03-16-2009 01:23 PM
