Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 08-15-2012, 02:37 PM   #1
Garage Door Opener Buzz
I have a 1/2 hp Craftsman chain drive opener that just buzzes when I press the wall mounted switch. I have a flashing green LED on the back, and pressing the reset button doesn't help any. Door will open freely when I unlatch the trolley. Any ideas?
pgr380 is offline   Reply With Quote
Old 08-15-2012, 03:37 PM   #2
Does it buzz momentarily, or does it continue to buzz until you press the button again? Also, a model number may help. In the mean time though, I would check the plastic drive gear on the top of the unit, to see if it is worn; it is intended to strip, break, whatever, rather than burning out the motor or other component, in the event that the door became jammed or otherwise inoperative.
Old 08-18-2012, 11:20 PM   #3
Needs a new gear kit. Plastic gear simple to replace. Just make sure you grease every groove of the gear with the supplied grease or you'll be doing it again in no time.
Darren R is offline   Reply With Quote
Expanding Garage INTO house (goodbye Den) texaopian Building & Construction 16 11-07-2011 11:32 PM
Detached garage subpanel options? jeffiebean Electrical 6 03-15-2011 09:20 PM
Garage remodel - adequate foundation? WillK Building & Construction 1 01-21-2011 02:50 PM
Garage Ideas? tripflex General Discussion 13 12-16-2009 08:06 PM
