Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 02-16-2010, 03:03 PM   #1
Garage door keypad stopped working
Craftsman garage door opener, about 7 yrs old. Keypad stopped working, changed battery, worked for about 2 or 3 times. Took out battery and replaced same battery, it worked 2 or 3 times and stopped. Replaced battery, and it worked 2 or 3x, and it stopped. Not interriment, because when it stops, it stops. Any suggestions?
bklyn1028 is offline   Reply With Quote
Old 02-16-2010, 03:23 PM   #2
jlhaslip's Avatar
Got the electric eyes? They might be mis-aligned.
Does the wall switch work okay and regularly without the stop action?
Have you dropped the remote?
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is offline   Reply With Quote
Old 02-16-2010, 04:26 PM   #3
Household Handyman
Answering jl's ?'s will probably solve your problem. If not, re-post and we'll try again. David
Old 02-16-2010, 05:20 PM   #4
Electric eyes are fine. Remotes in 3 cars work wonderfully. If I take the battery out, and re-install the same one, it works fine. The next day, it stops working. If I re install the same battery it works fine, then poof. Very frustrating.
Old 02-16-2010, 06:49 PM   #5
Xtreme DIY'r
Are you sure the battery is good ?
I've seen some right off the shelf that are almost dead
Other possibility is a short that is draining the battery
Old 02-16-2010, 07:22 PM   #6
jlhaslip's Avatar
Have you done any remodelling near there? Any chance of astray nail?
Open the keypad to see if it is wet inside.
Old 02-16-2010, 10:29 PM   #7
firehawkmph's Avatar
It sounds like the keypad is going bad on you. I have never had one do what yours is doing. The fact that it starts working after r & r the battery sounds like a bad connection in the keypad. I am assuming your keypad is a wireless craftsmen made to match up with your opener. If everything else is working fine, try another keypad, not worth screwing with. A liftmaster keypad from the same vintage will work with your sears unit.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 02-17-2010, 08:32 AM   #8
Mike Hawkins
Battery if fine, checked it out. No remodeling. Not wireless, wired into the jamb outside the garage door. Inside is clean, dry. I suppose I have to replace the keypad. Thank you all for your input.
Garage Ventilation Question eagle09tbl HVAC 5 10-22-2009 10:24 PM
Wiring a Shed and Garage abedj Electrical 1 05-08-2009 12:09 PM
Garage ceiling and attic storage DIY KEN Building & Construction 7 01-06-2009 05:57 PM
Air Compressor stopped working, extension cord was used. dawho1 Tools 3 10-07-2008 06:14 AM
Ice maker stopped working bragl01 Appliances 3 08-07-2006 09:59 PM
