Garage Door Issues, Not Enough Clearance... - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 05-22-2009, 07:26 PM   #1
Rewards Points: 408
Garage door issues, not enough clearance...
I knew there was a reason the previous owner didn't have garage door openers up! Damn. Well, we purchase two and I started to install them tonight just to find out when the door opens it hits the bar. What(if anything) can we do about this?
Garage door issues, not enough clearance...-img_0037.jpg   Garage door issues, not enough clearance...-img_0038.jpg   Garage door issues, not enough clearance...-img_0039.jpg   Garage door issues, not enough clearance...-img_0040.jpg
RyanD is offline   Reply With Quote
Old 05-22-2009, 07:43 PM   #2
They have different types of openers
Some that work from the side & do not need the bar
Old 05-22-2009, 07:53 PM   #3
Rewards Points: 408
Hmm, that sucks. :-( That means I will have to dismantle the two I built and try to salvage the $400 I spent.
Old 05-22-2009, 08:58 PM   #4
Tired & Dirty
Rewards Points: 83
You need a low head room kit. almost all door manuf. sell them.
evapman is offline   Reply With Quote
Old 05-22-2009, 09:32 PM   #5
Old School
Willie T's Avatar
You could try remounting the top rollers higher toward the upper edge of the top panel. But there is a problem with that, in that the door may not shut flat and flush if you remount them too high. You can't get into the curve with them when the door is shut, or the top won't seal.
Willie T
Old 05-22-2009, 09:34 PM   #6
Yes - but not that low
The doors themselves have low ceiling mounts
I doubt there is even 2" between that door & the ceiling ?
Old 05-22-2009, 09:53 PM   #7
Old School
Willie T's Avatar
This is exteme, but if the rafters/joists run the right way (probably don't, and that will kill this idea anyway), how do you feel about recessing an open bottom box beam up there? The bar could nestle up in the recess.
Willie T
Old 05-22-2009, 10:57 PM   #8
Registered User
Rewards Points: 526
First try moving your top rollers up higher. ( this may move the top of door too far from the jamb) You'll gain some, not a whole lot.
Or get some low overhead hinges: http://overheaddoorparts.com/qutubr1.html
Or just get some close radius jambs: http://www.edsgaragedoors.com/images/ts_lowheadroom.pdf
Or use a torsion bar spring and opener assembly. Be safe, G
Old 05-23-2009, 08:03 AM   #9
Rewards Points: 5,336
My brother had the same issue. The low clearance kit was no good either. He had enough room to move the whole unit to the back of the garage so no part of the garage door track was above the door.
I attached a long angle iron to the door and that "L" shaped piece of metal that would get attached to the door.
Works fine.
Ron
Old 05-23-2009, 06:20 PM   #10
I was in a garage the other day and I was looking around (why, I dont know, I cant stop looking at how stuff works). Anyway, they had two sets of track, the top panel ran on the lower track and the rest ran on the upper track. Does this make sense?
Occam's Razor - The simplest answer is probably the correct one.
JCAHILL4 is offline   Reply With Quote
Old 05-23-2009, 06:28 PM   #11
Registered User
Rewards Points: 526
See page 2: http://www.clopaydoor.com/publicfile...rev%202007.pdf
Be safe, G
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 02:57 PM
new double garage murray1426 Building & Construction 4 05-23-2009 01:11 PM
Garage ceiling and attic storage DIY KEN Building & Construction 7 01-06-2009 04:57 PM
Garage Door Install marly General DIY Discussions 2 11-17-2008 02:51 PM
