Garage Door Hard To Open - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-02-2010, 11:10 AM   #1
Rewards Points: 131
Garage door hard to open
I have a Wayne Dalton garage door about 10 years old and a Genie opener about 2 years old. For the past few weeks I have noticed that the door opens in a jerky fashion. Today it would only open about 6 inches. I sprayed some lubricant on the rollers. After a few more tries it did open but when I closed it it still seemed jerky. I am reluctant to open it again, as it's about 10 degrees here and I don't want to make the house too cold. Our pet bunny's hutch is also in the garage and I don't want to freeze out her as well. Any ideas on why the door is so jerky? Thanks in advance for any replies.
bucksone is offline   Reply With Quote
Old 01-02-2010, 11:32 AM   #2
Rewards Points: 6,652
Broken spring would be the first thing I would look for.
Old 01-02-2010, 11:39 AM   #3
the Musigician
DangerMouse's Avatar
what model genie? screw drive? chain?
DM
Old 01-02-2010, 12:12 PM   #4
Rewards Points: 1,016
Pull the disconnect on the operator - then see if it's the door or the operator.
Old 01-02-2010, 07:44 PM   #5
firehawkmph's Avatar
Rewards Points: 1,800
Like vsheetz said, start with pulling the disconnect cord on the opener and see if you can lift it by hand. If the spring is broke, you will know right away. Wayne daltons are built pretty light (weight wise). They use a couple of different spring setups. Make sure all the rollers are in place and cables running up the sides are intact. If a cable breaks, it will make the door very difficult to open. I would recommend calling a local garage door repairman. If you aren't experienced with garage doors, it's not a good diy project. Very easy to get hurt. If you need a new spring(s), or cables, it's not a real expensive repair. Let us know what you find.
Mike Hawkins
firehawkmph is online now   Reply With Quote
Raising up my garage jimmyfloyd Building & Construction 5 09-17-2009 11:39 PM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 03:57 PM
how to build an open garage? weedfan Building & Construction 12 05-05-2009 01:53 AM
garage door open light deck hand Electrical 3 01-22-2008 09:29 AM
