Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 04-15-2009, 10:12 AM   #1
Question
Garage door
Hey folks,
Couple days ago the garage door was closing and I heard a loud *snap*.
I looked around and didn't notice anything unusual, but then upon looking on the left side, I saw that a cable was very slack now.
The door still opens, but seems to labor quite a bit now.
In doing a little homework, I'm reading things about torsion bars....etc. Is this something I can fix myself? I attached a few photos.
Thanks all for any advice.
Brian
Badger_DIYer is offline   Reply With Quote
Old 04-15-2009, 11:40 AM   #2
47_47's Avatar
Garage door
Torsion springs store a considerable amount of energy. Many have been injured working on garage springs. I'm all for DIY, but in this case, call in a pro. I would also disconnect your opener and open the door manually and as infrequently as possible until the door is fixed.
What we've got here is... failure to communicate. Some men you just can't reach. So you get what we had here last week, which is the way he wants it... well, he gets it.
47_47 is offline   Reply With Quote
Old 04-15-2009, 03:10 PM   #3
gravity always wins
Garage door
If you disconnect the operator, you probably won't be able to open the door. Best bet is to leave it alone until someone can repair it. Continuing to use it will likely ruin the operator in short order. Torsion springs can break bones and wreck things pretty quickly if you make a mistake during repair. It's obvious you have no experience with them, so do yourself a favor, call in a pro.
Tags
garage door
Larson Storm Door Won't Close Snowbird Building & Construction 13 03-03-2009 04:01 AM
Garage Door Install marly General Discussion 2 11-17-2008 03:51 PM
Garage Door Leaking webweever Building & Construction 2 10-26-2008 04:04 AM
garage door lock jack_j General Discussion 1 12-27-2006 07:40 PM
Garage Door Opener - Noisy on Closing ? quantass Electrical 2 02-13-2006 03:09 PM
