Garage Door
Originally Posted by tunaman
I put some open cell foam on the inside of the frame and attached to it, just like you would drywall, I added some soundboard. The idea was to try and deaden some of the sound going through that wall.
What does this have to do with the door? Sounds like something is not right. Even the 1/3 horse should have worked, unless it was undersized to begin with.
As for the springs, anyone with half a brain can adjust the springs, unless they are torsion, then you are best to pay a door company to do the work.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Now listen, Cadet. I've got a job for you. See this button? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Don't touch it! It's the History Eraser button, you fool! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : So what'll happen? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
