Garage/Den Insulation - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-07-2008, 02:07 PM   #1
My den shares a wall with my garage. The den wall has built in shelves that extend out into the garage. My problem is that my den gets cold from the cold air in the garage. The wall in the garage is part drywall part cement block( around the back of the fireplace). So the wall doesn't have a very uniform look. I am looking for an easy way to add insulation particularly over the parts that are currently drywall. Any ideas on the best/easiest way to insulate?
Garage/Den Insulation-img_0438a.jpg
duffers is offline   Reply With Quote
Old 03-07-2008, 06:38 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 600
Ayuh,.....
How much space do you have between the block wall,+ door rail,+ hardware,..??
You might be able to box out,+ insulate both sides,+ just sheetrock over the block part.....
Old 03-12-2008, 08:03 AM   #3
There is about a foot and a half between the end of the drywall and the end of the block wall. When you say box out, you mean add put down a wood framing and then insulate that and then sheetrock it? is there any type of sheetrock that would come with insulation on it so i don't have to do the wood framing?
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
Insulation over Attic Walkway BigJimmy Building & Construction 4 06-23-2008 03:13 AM
attic insulation question dderolph Building & Construction 10 11-03-2007 06:21 PM
dormer window insulation wlm-21 Building & Construction 2 02-13-2007 05:04 PM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 09:33 PM
