Gap Between Ceiling And Brick Wall - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-16-2011, 04:09 PM   #1
Gap between ceiling and brick wall
Hello all,
I have a problem. Recently I hired someone to stripped the brick wall of paint inside my condo. But when they where finish there was an 1/2 inch gap between the ceiling and the brick wall. The person that I was dealing with said to just put a shoe molding there. I would rather not as I want it to be bare. What solutions would there be to seal up the gap? I believe 1/2 inch gap is too wide for just caulk. I would like to take care of this problem before I seal off the brick wall.
Thanks for all your help I have been searching for the answer and have not really found a solid solution yet.
ttnguy74 is offline   Reply With Quote
Old 01-16-2011, 04:16 PM   #2
Drywall and Painting Pro
Sir MixAlot's Avatar
Rewards Points: 908
Just get some foam backer rod.
Cut it to fit, put it in the gap and then caulk.
Sir MixAlot is offline   Reply With Quote
Old 01-16-2011, 04:28 PM   #3
Rewards Points: 5,336
Originally Posted by ttnguy74 View Post
Hello all,
It's a brick wall with a mortar joint. Put mortar in the 1/2" space.
Ron
DIY fireplace remodel gone awry - impenetrable brick wall shawnad73 Building & Construction 8 08-23-2010 08:52 AM
how to tell if a brick wall is load bearing eskowitz Building & Construction 10 08-01-2010 10:00 PM
Run wire to Breezeway through brick and up brick wall wad2k Electrical 0 04-16-2010 08:18 AM
Best way to cover over brick wall in basement? tigereye Remodeling 4 04-14-2009 10:24 PM
How to fill a gap between basement ceiling and brick wall simonw Building & Construction 5 01-12-2009 01:00 AM
