Fuse Added To Replace Rollout Switch - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-14-2010, 05:56 PM   #1
Fuse Added to replace Rollout Switch
Another post, forgot to mention on my Bryant 345MAV048100ACKA furnace: last time furnace repair came out he shorted the rollout switch with a 3amp fuse link. Is this safe or ok or what?? wires do not go to the rollout (manual reset) switch now at all, just go through the 3 amp fuse. This didn't fix the issue anyhow but helped his finances out I'm sure.
TruckTahoe is offline   Reply With Quote
Old 12-15-2010, 11:15 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 334
Ayuh,... If you'd put All the info in a single thread, folks would have a better idea of what's up, 'n you'll get better answers...
Nobody is going to search this Whole forum to find your scattered posts...
And,...
Why isn't this All in the Hvac forum, after all, it's All a Hvac problem...
'n another thing,...
What's with the Tiny font,....
Many of Us here are gettin' older...
If you want answers, ya gotta work With Us, instead of against Us...
The Following User Says Thank You to Bondo For This Useful Post:
TruckTahoe (12-15-2010)
Old 12-15-2010, 01:29 PM   #3
New to the site and learning.
Old 12-16-2010, 11:04 PM   #4
Rollout Switch is a safety switch, at 250 degrees it shut the unit down any one that by passes it is a fool and pudding your house and family in danger.It sounds like you have a restricted secondary heat exchanger
Swift is offline   Reply With Quote
The Following User Says Thank You to Swift For This Useful Post:
TruckTahoe (12-17-2010)
3-way switch help amit Electrical 17 02-15-2010 04:17 PM
Flame rollout switch rmason HVAC 5 01-21-2010 08:36 AM
Bedrooms have no ceiling light, light switch controls one electrical outlet? notenoughtime Electrical 16 05-25-2009 01:09 AM
Detached garage adding a 3 way switch. Slatherd Electrical 4 01-02-2006 03:53 PM
looking to replace a rotary switch Unregistered Electrical 1 03-31-2004 01:57 PM
