Furnace Gas Conversion - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 06-29-2014, 10:43 AM   #1
I have a York Furnace that runs on LP. Due to recent LP cost increases, I am considering converting the house to Natural Gas. Most of my appliances are easily converted but I am having trouble determining what, besides the burner orifices, needs to be changed on my furnace to make it work on Natural Gas.
The gas valve in the furnace has a sticker on it that says LP but the part number looks to be exactly what the NG part number is. Do I need to change this?
Any insight would be appreciated.
jjhoglund is offline   Reply With Quote
Old 06-29-2014, 11:27 AM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 188
Yes. There is a different spring for nat gas vs propane. The spring controls the regulator/pressure from the valve. Check with York if the spring is available or whoever makes the valve ie: Honeywell or White Rodgers
Old 07-09-2014, 10:40 AM   #3
I prefer Honeywell, do you?
europaving is offline   Reply With Quote
Old 07-09-2014, 12:13 PM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,228
Most often those regulators are convertible. You remove the plastic cap and reverse the insert. google the model number and you should find the manual that details the conversion process.
Coastal South Carolina
Lennox G40UH furnace stops and fails to start at nights only Muscovite HVAC 20 03-12-2014 01:44 PM
Older Trane 90xl Furnace Perry401 HVAC 1 11-15-2013 12:00 AM
Chimney flue relining or another option - Oil Furnace Expert Needed thp HVAC 22 11-08-2013 09:18 PM
Furnace conversion Heoman HVAC 3 12-05-2010 08:30 PM
Olsen BFL 120 Furnace DaleB HVAC 12 12-19-2008 10:42 PM
