Funky Smell In The House - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-20-2012, 01:26 PM   #1
Rewards Points: 258
Funky Smell in the house
Hello, I need help trying to get this funky smell out of my house and I have no idea where it is coming from.
Just started about 2 weeks ago and not sure where its coming from and we KEEP A CLEAN HOUSE for you people out there thinking I'm a dirty old guy.lol
And its probably even cleaner now since this smell.
The smell is like a musty/sour smell.
I just got done drywalling the basement and priming the walls. Haven't painted yet and still cleaning up the dust in the basement. The basement doesn't smell so I don't think its down there. Its the upstairs that stinks and I have fans going and windows open to ventilate everything.
Tonight I'm going up to the attic to see if anything funky or dead is up there. We don't have a crawl space fyi.
Please help!!!
jburchill is offline   Reply With Quote
Old 03-20-2012, 01:55 PM   #2
Rewards Points: 14,306
Dry trap in a sink, shower or tub that gets little use, leaking toilet wax ring.
If it may be a trap just drump some water in the drain.
Condinsate pan under the refigerator full of nasty water.
Old 03-20-2012, 02:03 PM   #3
Rewards Points: 258
The basement doesn't get used a lot, but I'll pour some water down the drain in the tub. The toilet has a plug in it due to flooding two years ago and haven't had any smell yet. But I don't smell anything in the basement really.
For the fridge, we have a new fridge is the pan hard to get to?
Old 03-20-2012, 02:06 PM   #4
Most ref. just have a snap on cover in the front at the very bottom. Remove it and the pan just slides out.
Old 03-20-2012, 02:53 PM   #5
Rewards Points: 626
dead mouse or rat in a wall?
Nailbags is offline   Reply With Quote
Old 03-20-2012, 02:57 PM   #6
Rewards Points: 258
If that is the case, I would just have to ride that out one would think. How long does that last about a couple weeks?...I'm going in the attic tonight to see if anything leaked through during spring
Old 03-21-2012, 11:20 AM   #7
Rewards Points: 258
Nothing in the attic, looked dry and didn't smell. I'll have to go check it out after it rains.
Old 03-21-2012, 12:35 PM   #8
Too Short? Cut it Again!
Once tried for ages to trace a horrid foul smell in one of my first apartments. My significant other and I were clean and were not aware of any dead animals. After weeks it turned out to be potting soil for a hanging plant that had gone sour. Leached it thoroughly and the smell went away.
Old 03-21-2012, 01:10 PM   #9
Rewards Points: 258
I have bleached under the sink, and have a dehumidifier going. I do not have the central air going but the smell is better..well a little better.
I will later turn on the central air and see if that makes it worse. I hope a mouse didn't die in a vent...that would suck!!
Old 03-24-2012, 11:15 PM   #10
Rewards Points: 258
I think I found the problem. I brought in some paint cans from the garage that been there all winter. I think they froze and got moldy or something rotten in them. I put them back outside and the smell as gone away.
The Following User Says Thank You to jburchill For This Useful Post:
oh'mike (03-30-2012)
Old 03-29-2012, 07:21 PM   #11
Rewards Points: 55
Had this happen twice for different reasons.
First time turned out to be water level in a toilet too low and letting sewer gases in. Second was an unopened can of cat food in the pantry that was bad (bad seal or small puncture) and smelled like a dead animal in the walls.
Italgrl is offline   Reply With Quote
Old 04-06-2012, 03:42 PM   #12
Check to see if there are any leaks or a creature might be dead behind the walls. i am not sure how you can find out whether or not you have something dead in your house but I am sure there could be some information on the internet. Good luck
lynnbrwn is offline   Reply With Quote
Smell coming from all floor registers. John_W HVAC 10 08-07-2015 06:42 PM
Remove Burnt Smell From House sweaty General DIY Discussions 14 02-29-2012 12:20 PM
Considering buying a house that needs regrading HELP Dr.JUSC Landscaping & Lawn Care 9 06-16-2011 10:58 AM
septic issue? musty smell in house, and toilet won't flush karen71 Plumbing 5 02-18-2010 03:14 PM
insulation smell in my house baby12121 Building & Construction 5 02-02-2010 08:45 AM
