Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 11-08-2005, 01:13 AM   #1
Funk In Bathtub...
Hello everyone,
I have a slight problem in my bathtub that is mostly just a nuisance but I haven't figured out how to get rid of the problem. Inside the tub there is some kind of funk that looks like dirt but will not go away. Its a brownish color and I have tried EVERYTHING to remove it! I've bleached the tub more than a few times and scrubbed relentlessly and it will not go away at all.
Does anyone know of any "magic" solution for cleaning tubs? I have considered re-glazing the tub but don't know much about the process. Can it be a do-it-yourself job or do you need a contracter? Any ideas or info would be greatly appreciated!
Nick
kalaniwavo is offline   Reply With Quote
Old 11-08-2005, 06:54 PM   #2
Contractor
Funk In Bathtub...
Try some pool chlorine on a Q-Tip on a small spot. Rinse well after testing. Failing that, try RustAid using the same test. I'm talking the size of the end of a Q-Tip here, don't smear it over a 4" section. Rinse well again.
I'd be surprised if one or the other doesn't clear it up. If not, come back.
Teetorbilt is offline   Reply With Quote
Tiling over a bathtub lip The Kid Remodeling 19 02-04-2012 12:46 PM
Help with ID'ing bathtub sound... DIY-Gal Plumbing 12 02-10-2007 06:45 AM
Bathtub Drain partially closed??? Sellncars Plumbing 3 08-14-2006 01:43 PM
peeling bathtub drunkugly Plumbing 4 07-13-2006 09:35 PM
Leaking Bathtub woodinville guy Plumbing 3 09-01-2005 02:32 PM
