Front Porch Drainage - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 09-08-2012, 06:17 PM   #1
jstar571's Avatar
Front porch drainage
Help! Need ideas
Front porch is a epic fail in drainage. Attached are photos. The water isn't going out to road.... It's seeping into ground into basement.
Driveway is asphalt on top of I think cement.
Ideas? Suggestions?
Front porch drainage-image-424387715.jpg   Front porch drainage-image-2235161020.jpg   Front porch drainage-image-2024721528.jpg
jstar571 is offline   Reply With Quote
Old 09-08-2012, 06:23 PM   #2
Rewards Points: 13,694
For one thing your down spout does not even run to the ground with another long piece at the bottom leading out to the street.
Old 09-08-2012, 06:30 PM   #3
I can't believe you are letting the water drain right there. Get an extension that reaches the first step without being a trip hazard.
creeper is offline   Reply With Quote
Old 09-08-2012, 06:34 PM   #4
jstar571's Avatar
I think it was done that way due to lack of room available for a extra piece. I plan on getting a piece that can add on to it as a temporary fix unless it works..then unsure..
Old 09-08-2012, 06:56 PM   #5
Not sure why it would not "fit". Two elbows and another section of down spout is all it would take.
Old 09-09-2012, 09:59 PM   #6
jstar571's Avatar
I'm concerned that once its in that ledge it will fall off. Not sure how I would secure it to the wall
Old 09-10-2012, 04:56 AM   #7
DIY staff
Rewards Points: 7,174
Is the brick work newer than the porch? Is water pooling between the porch deck and brick work---then slowly seeping through the brick work?
Looks like you may need to remove one brick at the bottom to add some drainage----
Old 09-11-2012, 11:30 PM   #8
Bombastic Idiot
notmrjohn's Avatar
All the water from entire roof served by that down spout is not seeping but pouring straight into basement. how long has it been like that? You gotta get it away from there now.
"Not sure how I would secure it to the wall" With down spout hanging straps and masonry fasteners. You can get a small package of Tapcon screws with bit at Home depot. Just be sure not to over tighten them. Also fasten all pieces of drain to each other sheet metal screws. Each piece goes inside next piece down stream. and seal each joint, especially on the more horizontal piece.
A cheaper, temporary procedure would be with flexible plastic extensions. Key words; cheap thin plastic and temporary. Plastic is not gonna hold uop long in that exposed place. There should be some around six fet long at Home Depot. Or Take that elbow off. work the end of flex up over down spout, seal and screw it on. Run it down wall to drive and bend towards street, seal and screw next one on, and keep going till you're as close to street as you can, looks like the steps the limit. Luckily it looks theres at least a small drop from asphalt there. brace the flex out of way against wall, bricks or what have you. Or run it along the ledge up off ground then on down.
"The water isn't going out to road." How is the water flow of rain falling directly on drive or flowing onto it from places other than that down spout. Does it make it to road without running right along side of house? Doon't go dumping any asphalt or anything along there trying to seal out water. If it comes to regrading drive really check out basement for any damage that needs repairing and make them first. You don't want to have to rip out new drive work to repair anything down there. Really examine the basement on that side I don't think I like the way that asphalt was done along there.
Don't know how long the ledge and porch are, looks like when you do real downspout, which could be now all you need is one piece of spout or two. two A and two B elbows, few haanger straps, anchors , sheet metal screws and gutter sealant.
Do something quick before major basement and structural damage occurs and let us know how its going.
Measure twice, cut once.
Look at the nail, not the hammer. Watch the fence, not the blade.
If you hook your thumb over your belt you won't hit it with the hammer or leave it layin on the saw table.
notmrjohn is offline   Reply With Quote
Please help with concrete front porch and step mdambrosio Building & Construction 6 05-26-2011 07:48 AM
Need opinions/feedback for front sidewalk and water drainage idea (photos) HautingLu Landscaping & Lawn Care 2 04-29-2011 10:58 PM
Operation Front Porch = Outdoor room Complete! Leah Frances Project Showcase 14 04-27-2011 09:14 PM
Porch Flooring Recommendation RyanS. Flooring 0 04-16-2011 11:31 AM
wood front porch steps dlhein Carpentry 4 05-11-2008 08:06 PM
