Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 05-30-2009, 10:30 PM   #1
Default Front door side lite plastic molding
Hello everyone. I just joined this site in hopes of getting some advice and or help. I do custom woodworking plus I help with odd jobs that friends always seem to need done. I have a friend that is strapped for money and needs to fix a molding around a window side lite on a front door. The side lite looks like it is styrofoam with a thin plastic shell bonded to it. A rectangular opening is cut into this. A dual pain glass panel is held in the opening by two plastic trim pieces that are placed into the opening around the window fro both sides. Screws go through from the inside and thread into the outer moulding.
The outer molding is cracking and falling apart. I can imagine that there are many varieties of molding types and sizes. I just need to find out where or who I can get this type of molding from.
I thought about making new molding from wood but it appears that the glass actually sets on and is centered by plastic protrusions that extend from the inside moulding. Once the screws are removed evertyhing including the glass will fall out.
Any help or advice would be appreciated.
Thanks, Franky5
Franky5 is offline   Reply With Quote
Old 05-30-2009, 10:49 PM   #2
Building codes guy, Mod
thekctermite's Avatar
There's a pretty good chance the the moulding is proprietary as part of the window manufacturer's door/window assembly.
Years ago you could find the type of trim you described in occasional yards and hardware stores. I can't think of anyone that sells it these days. They do still use it in trailer homes. The stuff is awful to work with and it really does just look like plastic wood.
You could mill the trim out of wood thicker than what shows and cut a rabbet in the back of it to support the glass inside the unit. Or you could use some rectangular "stop" material to hold the glass at the right height and lateral position instead of relying on the trim to do it.
The building code is a minimum standard, and merely meeting it instead of exceeding it equates to building your project to the worst standard that the law will allow.
thekctermite is offline   Reply With Quote
Old 05-31-2009, 12:16 AM   #3
Try contacting the door manufacturer for a replacement part. The relationship of the molding/door and glass will be very hard to replicate from the sound of it. Plus, anything you might fabricate, might not provide the needed cushioning to prevent the glass from damage.
Ron
Old 05-31-2009, 09:01 AM   #4
Try looking around for a Habit for humanity store to see if you can match the moulding or contact a local door manufacturer with your door info, brand etc.
I have met several manufacturers locally and my understanding is they are assemblers of products supplied by other companies... Or call a glass shop, surely side lights get damaged and they need to replace trim on occaision...
Chemist1961 is offline   Reply With Quote
More On This Topic
Clay Slump Molding Tips
Clay Slump Molding Tips by Expert Village
Another way of working with slabs, is called slump molding. It's the opposite of hump molding. In hump molding you're laying the clay over a form over a hump. In slump molding you're laying the clay inside of a form. And you're letting the clay slump... Read More »
Remove the negative socket from the plastic mold. Learn how to make a prosthetic leg with these video instructions. Read More »
So the first thing you are going to need is to find a mold. In traditionally a mold for a sugar skull would have been made out of wood or clay or ceramic or something like that. They still make them like that in Mexico and parts of Latin America. You can... Read More »
Limoncillo Mixed Drink
Limoncillo Mixed Drink by Expert Village
Alright the drink we're about to make is called a Lemonshillo. And we're going to take a glass and fill it up with ice. And we're going to add two ounces of rum. White rum to be exact. And we're going to fill it up with Crystal Lite. Lemon Crystal Lite... Read More »
Hi, I'm Gail Hoffman from Middltown Beach, Florida. On behalf of Expert Village I'm going to make for you a baked Alaska. To make baked Alaska you need a few ingredients egg whites for the meringue, sugar to add to the egg whites to make a nice glossy... Read More »
Crown molding on with catherderal celing for LED lights My_attempt Carpentry 20 07-22-2009 12:52 PM
Paint Crown Molding Before or After Installation? gmhut Painting 24 06-03-2009 10:38 PM
Re-tiling a bathtub surround BillyB44 Remodeling 37 05-13-2009 09:05 PM
Any Tips on Installing Plastic Molding? 1655graff Remodeling 4 11-28-2008 09:36 PM
Help with adding a strip of molding over baseboard. Bobrobert Remodeling 15 01-16-2008 12:12 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
