Front Door Insert....how To??? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 06-13-2009, 10:54 AM   #1
Front door insert....how to???
Hello,
I bought a door insert for our steel insulated front door.
What is the best way that I can do it myself?
Thank you!!
Neil_n_Robyn is offline   Reply With Quote
Old 06-13-2009, 01:44 PM   #2
Rewards Points: 5,336
Originally Posted by Neil_n_Robyn View Post
Hello,
Thank you!!
Is this a flush door? Flat on both sides?
What tools do you have? What sort of experience do you have working with a grinder or circular saw?
How big is this insert? Is this a window?
Post a picture if you don't know the type of door you have.
Ron
Old 06-14-2009, 08:25 PM   #3
It was easier than I thought...
We got our drill, drilled a hole, inserted the jigsaw in that hole and cut the door. Then we put in the insert and screwed it together .... we are all finished!!
Old 06-14-2009, 08:53 PM   #4
And no pics ??
Tile on Front Porch PearlWhiteGT Flooring 8 04-24-2009 02:43 PM
Front Cement Steps / Porch Leaking bschwarz Building & Construction 2 04-14-2009 11:46 PM
Adding new Front Porch, need opinions MeraleeCrowl Remodeling 1 11-05-2008 01:47 PM
Cracked ledger board on front porch King_Doodle Building & Construction 20 06-03-2008 10:16 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
