Front Door Exterior Trim - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 08-23-2009, 12:52 PM   #1
Front door exterior trim
My front door trim outside was never painted. It only had primer on it and now it is starting to chip away. I sanded the chip away pieces off. Do I need to scrap off all of the primer? Most of it is on there pretty good.
Joefeno77 is offline   Reply With Quote
Old 08-23-2009, 01:59 PM   #2
Remodeling Contractor
you only need to scrape off the loose pieces. then sand edges to feather. Prime again, then two top coats of acrylic latex.
Front Door - Door stops? 1655graff Carpentry 6 08-14-2009 12:40 PM
Ceramic or Porcelain for Front Room/Living room (advice needed) irishgem@ymail. Flooring 4 07-08-2009 01:46 PM
Front Cement Steps / Porch Leaking bschwarz Building & Construction 2 04-14-2009 10:46 PM
Adding new Front Porch, need opinions MeraleeCrowl Remodeling 1 11-05-2008 12:47 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
