Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 03-26-2012, 01:33 PM   #1
Front door, concrete water damage
Finally closed on my house! Each time I visit I find more and more projects. I've at least narrowed it down to the first project I would like to complete.
Water will run off the overhang above the front door and land on the concrete stairs and they have essentially turned to dust. Any ideas on what can be done with this to divert the water while keeping good aesthetics as much as possible?
dcase84 is offline   Reply With Quote
Old 03-26-2012, 03:07 PM   #2
May want to take a picture in the day time so we can see it. Your is all black.
Old 03-26-2012, 03:12 PM   #3
Yeah I know. I usually don't get out there until later after work.
Can you at least make out the basic concept of what is constructed?
It is basically a small sloped roof over the front stairs and landing. Unfortunately it is sloped towards the sidewalk/stairs instead of sloping to the sides of the landing.
Short of rebuilding the overhang to resemble a typical roof structure I really don't know what do do with it.
I'll try to get to the house earlier tonight so I can get a picture in the light.
Old 03-26-2012, 03:18 PM   #4
Custom User Title
A gutter will solve your problem. However, it will certainly take away from the aesthetics.
no1hustler is offline   Reply With Quote
Old 03-26-2012, 03:32 PM   #5
I've considered that too, however, like you said, it will just make this thing even uglier. If I could find some siding I would just rip this thing off entirely.
Old 03-26-2012, 03:43 PM   #6
joed's Avatar
Take the siding from another side of the house where you patch it and it won't be as noticeable. If you have a small wall or section perhaps reside the entire wall and use the pieces removed for patching.
Do not PM with questions that can be asked in a forum. I will not respond.
Old 03-26-2012, 07:42 PM   #7
Hard to see in your pic, but, it looks like you have an overhang with the roof
and gutters above, which is good. Not sure what you have for siding, is it vinyl? I would look at option to remove it. Or, replace with a larger overhang to divert water away from steps. Need to see house more clearly, to determine if that makes more sense. Is this a colonial or ranch style home?
pesos is offline   Reply With Quote
Hail Damage Claims Myths/Facts Roofmaster417 Roofing/Siding 5 08-03-2011 04:04 PM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 01:01 AM
Cement cracks in foundation after water damage Ginette Building & Construction 4 09-06-2010 07:14 PM
Water damage. How bad can it be? alexin General Discussion 3 08-23-2010 02:53 PM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 09:42 AM
