French/Trench Drain Sucesses? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 06-17-2008, 10:58 AM   #1
French/Trench drain sucesses?
I had already talked about this some but wanted to ask if anyone had dug a trench around their foundation perimeter and installed tile/gravel and actually had it stop water from going into their basement. Ours gets about 1-2" of water during heavy rain, we are on flat land so we cannot positive grade since our basement was put in too deep (the dirt would have to meet the siding if we did), so the grading is about flat or even slightly negative in some areas. If you did the trench drain how deep did you dig and did you do it right up against your foundation or out a couple feet? Also, how big of gravel did you use?
annie68164 is offline   Reply With Quote
Old 06-17-2008, 05:36 PM   #2
Advice worth 2 cents!
Rewards Points: 150
Of course drains work! But, my city allows us to connect the french drain to the sewer so, without proper evacuation your screwed. Google the subject and you'll see how to install the drain, it's really easy to do. I'd also recommend applying an elastomer membrane to the outside wall.
- pete
---pete
HandyPete is offline   Reply With Quote
Old 06-17-2008, 10:51 PM   #3
Rewards Points: 258
http://www.askthebuilder.com/070_Lin..._Seepage.shtml
Here is a interesting short article on the subject.
Docfletcher is offline   Reply With Quote
Old 06-17-2008, 11:17 PM   #4
thanks docfletcher. I had actually read his articles on trench and french drains but hadn't read that one. It had an excellent illustration and good info and testimonials from people who had done it.
Old 06-18-2008, 12:37 AM   #5
Rewards Points: 258
Your very welcome...
Wierd Floor Drain "Backup" rawkintrevo Plumbing 9 06-04-2008 08:10 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
Washer drain peloncito Appliances 7 08-04-2007 01:56 AM
How to outline the 1 1/2" PVC drain froddan Plumbing 6 07-24-2007 04:15 AM
Need to move a tub drain to line up with a new tub, is it ok to do this... *PICS* J187 Plumbing 6 05-23-2006 12:13 AM
