French Drains - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 09-25-2013, 12:43 PM   #1
french drains
Hi I was wondering if someone would be able to help me with a question about French drains. I recently had french drains installed around our pool area.I was supposed to put pea gravel around it but I noticed that the water was not going into the ground so it looks like a have a mote around my pool. Is it supposed to do that or are the drains supposed to suck the water down and bring it out to the street? We never had a problem with water just sitting around and now we do. Can somebody help me out with this problem? Thank you.
JoannaB. is offline   Reply With Quote
Old 09-25-2013, 03:05 PM   #2
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
It won't "suck" the water down. It is strictly gravity. With a french drain the water should work its way down into a perforated drain or pipe and discharge or dump out to an acceptable (lower) area. Sometimes it is out to a visible lower slope. Sometimes into "dry well" or something similar that will hold the water until it can be absorbed into the ground.
Do you know where the water is supposed to discharge?
A pic or two might help.
The Following User Says Thank You to Blondesense For This Useful Post:
concretemasonry (09-25-2013)
Old 09-25-2013, 04:53 PM   #3
concretemasonry's Avatar
Rewards Points: 2,642
It sounds like an installation that is supposed to collect water and and then discharge it local a little deeper. That is not the common use of a french drain.
One classic method around water sources is to collect the water with a gutter system, run it away with a solid pvc pipe and then spread the discharge out over a larger area further away using a perforated french drain to spread out the discharge (opposite way they were originally used for collection).
Dick
concretemasonry is online now   Reply With Quote
Old 09-25-2013, 08:07 PM   #4
One picture shows our gutter going down to a pvc pipe which then attaches to our french drains. The other photo shows our problem The water is supposed to get discharged through two pop -ups that are on both sides of the house. This is not happening and we are now blessed with a mote. I hope with these photos it allows you to see our problem. Thank you again for all your help.
Old 09-25-2013, 08:37 PM   #5
I don't know about where you live, but at my house, things like French drains can, over time, become clogged with sediment. Is the pea gravel still visible or has mud covered it all up?
oberkc is offline   Reply With Quote
Old 09-26-2013, 09:02 AM   #6
I have not laid the pea gravel down yet since I noticed the drains are not functioning correctly. Or are they? The water does seem to disappear after awhile but as soon as it rains again even if it's a little rain it becomes a mote again. Just frustrated never had this problem before without these drains.
Old 09-26-2013, 03:15 PM   #7
In that case, I would conclude that there is not adequate slope to the discharge. My experience is that these things can carry enough water away that they would avoid this problem.
Old 10-14-2013, 08:38 PM   #8
The only function of the pea gravel is to filter out the sediment before it reaches the drain pipe so it that doesn't accumulate and bridge over which, will lessen the capacity over time and eventually clog your drain. The only time you should have standing water in your drain is if you have a torrential rain and even then it should be only for a very short time. I would say there are several possible causes for the problem you have including but not necessarily limited to insufficient difference in grade to facilitate drainage, an under sized drain pipe, or a clogged drain pipe. Do you know where the drain is supposed to dump? If the French drain was installed recently or in the past few months there should be evidence of disturbed soil that would be a good indicator of the route that the drain pipe takes to where the water that is collected in the drain dumps out (the area where the drain is supposed to dump should also be at a lower elevation than where the actual French drain is too).
Keegans is offline   Reply With Quote
Old 10-14-2013, 08:40 PM   #9
I would have whoever installed it come back and fix it.
The Following User Says Thank You to Keegans For This Useful Post:
mj12 (10-20-2013)
Water in Basemen....Sump Pump or French Drains? wrea398 Plumbing 9 04-17-2013 06:33 PM
Installing French Drains Near Roots and Trees sdent Plumbing 3 04-13-2013 09:37 PM
Walls on top of interior french drains in basement? canoes General DIY Discussions 8 12-30-2011 04:01 PM
Doing trenching and french drains, what else to do at same time? HautingLu General DIY Discussions 0 04-20-2010 10:50 AM
French drains Toolmaster Building & Construction 5 10-17-2009 04:37 AM
