French Drain Or Perimeter Drain - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 09-15-2011, 09:34 AM   #1
Rewards Points: 150
French drain or perimeter drain
Hi,
I know this seems like a long shot, but is there a way to know if I have a french drain or perimeter drain around my home? I dont have any water infiltration in my basement, never have (knock on wood). I may try to call the previosu owner, but he may have moved away, Ill have to track him down.
Thanks!
sbmfj is offline   Reply With Quote
Old 09-15-2011, 12:06 PM   #2
Is this wire Hot?
Oh-Fudge's Avatar
Rewards Points: 170
Hi sb, I'm no expert but can you just grab a shovel and see what's under the dirt outside your foundation? Aren't these drains just below ground level?
Also, just curious, why you need to know if you have no problems or leaks?
Oh-Fudge is offline   Reply With Quote
Old 09-15-2011, 12:09 PM   #3
Civil Engineer
Rewards Points: 4,518
If you have pipes that connect to your sump pump, there is a high probability you have a perimeter drain. If you want to be sure, you need to excavate, which is a lot of work if you have a basement, which it sounds like you do. Of course, if you have a walkout basement, start on that side. There are arcane techniques for finding underground piping like subsurface penetrating radar, but a good old shovel should do the job in your case.
Old 09-15-2011, 01:51 PM   #4
Rewards Points: 150
ok, thats what I thought, meaning Id have to dig.
No water issues at all, just wondering. I have a basement window, and an old window well, will be replacing both. Wanted to ensure the water that accumulates in the well can evacuate correctly. so far it always has, just wanted to know if theres an easy way to see if I had a perimeter drain.
Thanks!
Old 09-16-2011, 10:52 AM   #5
Rewards Points: 3,130
A long shot perhaps, but you might check with your local building department. It may be that code specifies what must be installed. Where I live, virtually no new construction homes (including mine) have an actual French drain. A perimeter drain with the flexible, perforated pipe is much easier and cheaper to install.
dig trench to install internal french drain is ok on a no footing basement? diy001 Building & Construction 0 01-14-2011 04:10 PM
French Drain Suggestions doublejz Landscaping & Lawn Care 10 04-29-2010 04:19 PM
Interior French Drain cougar01 Building & Construction 3 03-29-2009 12:51 PM
Determining existance of French Drain cmarti02 Plumbing 2 11-07-2007 07:51 PM
French drain question Tom Fan Landscaping & Lawn Care 3 06-04-2007 07:16 PM
