French Drain To Nowhere - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-14-2013, 04:43 PM   #1
French Drain to nowhere
It now looks that a basement moisture problem is related to a large terrace way above grade that was simply filled with clay/dirt on the assumption it would drain and not seep into basement.
Am thinking I could try running two drain pipes from the terrace out to the back at a depth a few inches below the level of the basement interior drains.
It feels like some of the terrace fill has leeched out to the basement and the yard.
It's about 60 foot to a place where a pipe can come out.
Thanks for any input
Twyllie is offline   Reply With Quote
Old 12-14-2013, 04:46 PM   #2
Rewards Points: 13,446
A picture so we can see what your seeing is always nice.
Twyllie (12-15-2013)
Old 12-15-2013, 08:32 AM   #3
https://drive.google.com/file/d/0B4H...it?usp=sharing
Here is the link to the google image.
Behind the terrace is dry crawlspace
The right side with casement windows is dry at ground level. But there is a sub basement three feet lower that gets the moisture.
At the terrace base in corner by picture window, you can see where clay from terrace fill has been pushed under the footiings and up.
The grade from the terrace base is flat for about 50 ft and slopes a further 6 ft thereafter.
Hope this helps.
Old 12-15-2013, 09:02 AM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,012
Ayuh,.... Yer link don't work,....
The Following User Says Thank You to Bondo For This Useful Post:
Old 12-15-2013, 09:16 AM   #5
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,044
https://docs.google.com/a/windowsonw...llMjJsaWM/edit
The Following User Says Thank You to Windows on Wash For This Useful Post:
Old 12-15-2013, 09:17 AM   #6
This image should work by pasting in your browser window
Board tells me I need more posts for images to be displayed. But I would think a google link to my google drive would work by pasting.
French drain or gutter downspout? stevekem Concrete, Stone & Masonry 7 08-17-2013 01:16 PM
French Drain Merge into Solid Drain catahoula22 Landscaping & Lawn Care 0 07-19-2013 01:38 AM
Connecting shower drain to toilet drain Liv Plumbing 10 04-17-2013 10:53 PM
what to do with the french drain behind a retaining wall MLMIB Building & Construction 4 04-08-2011 07:52 AM
French drain question Tom Fan Landscaping & Lawn Care 3 06-04-2007 06:16 PM
