Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 07-16-2010, 10:11 PM   #1
french doors
Is it possible to buy the plastic frame around exterior french door windows, which is held together by screws from the inside of the door, without the lattice-style center which is also plastic?
dennisjarman is offline   Reply With Quote
Old 07-17-2010, 07:11 AM   #2
french doors
Are you asking about the removable grid frame without the grid??? If yes, maybe. Some manufacturers will make it in any configuration you like, others have only specific layouts available. Some use wood, some use plastic.
Old 07-17-2010, 10:37 AM   #3
french doors
thank you, just bill,
Any idea on where I can purchase the plastic grid only?
Old 07-18-2010, 07:30 AM   #4
french doors
See if you can find the manufacturers name somewhere, sometimes under a hinge. Idealy it should come from the manufacturer. Lumberyards are usually a big help in finding odd things. Big box is not the place to look.
Old 07-18-2010, 09:41 AM   #5
french doors
Thank you very much. Great advice.
Thanks to my wife, installing a set of French Doors BJLower Remodeling 4 04-04-2010 09:07 PM
French doors help... macdc Building & Construction 3 01-24-2010 12:17 AM
Exterior french doors install? imola ghost Carpentry 3 11-16-2009 06:06 AM
Replacing Sliders with French Doors ElizaWhyza Remodeling 2 03-31-2009 11:26 PM
French Doors That don't Match! terryb Building & Construction 21 12-17-2007 08:19 PM
