French Door Outswing - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-03-2008, 09:50 AM   #1
I would like to install a 5 foot Outswing Right hand unit French style Patio door. THis is imperative do to existing contruction and limited space available. Lowes only sells an Inswing Left hand unit in Houston and to order what I want will cause the price to double, yes double. Is it possible to alter the sill assembly or reverse the hinges to achieve what I want? How complicated is this.
handyandy2 is offline   Reply With Quote
Old 03-03-2008, 10:26 AM   #2
wfischer's Avatar
If I'm understanding this correctly, couldn't you just turn the whole thing around 180 deg? Then move the doorknob accordingly.
wfischer is offline   Reply With Quote
Old 03-03-2008, 10:44 AM   #3
Thats what I was thinking but the threshhold sticks out further on the outside to hang over the foundation. Thought that might cause a problem as far as being weather tight? Thanks for the reply!
Old 03-03-2008, 12:49 PM   #4
Mold!! Let's kill it!
Rewards Points: 2,012
Most of the time the threshold on an outswing door is designed different from an inswing in the way it sheds water. You would need to put the brickmold on the outside which isn't a big deal, but the threshold won't reach out to match the same projection.
Old 03-03-2008, 02:14 PM   #5
Rewards Points: 5,336
No, you can't reverse an exterior door swing. It's the weatherstripping thing.
What price point are you looking for, for this unit?
Ron
Old 03-03-2008, 04:18 PM   #6
also..you need tamper proof hinges for security..they will be on the outside.
johnrem is offline   Reply With Quote
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
French Doors That don't Match! terryb Building & Construction 21 12-17-2007 08:19 PM
How to install a french door????? Jen @ J-town General DIY Discussions 6 07-30-2007 04:35 AM
French door installation dale_jr. Carpentry 6 07-23-2006 06:24 PM
