French Door Mortice Locks - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 06-24-2009, 03:47 PM   #1
French door mortice locks
I bought a set of French doors at a rebuilder supply without the hardware thinking I could to the home supply stores and get what I needed. Now I cannot find it.
The door are morticed, inswing left hand and I am trying to find out who made them originally so I can buy the right kit. The glass has what looks like the milgard logo and a date of 1975. Milgard says they did not make French doors in 75, now I am at a loss. They are framed in and I cannot secure them.
siolence is offline   Reply With Quote
Old 06-24-2009, 03:58 PM   #2
DIY'r
ScottR's Avatar
If you end up not being able to find the hardware, you could fill in the mortise and re-drill for a stock cylindrical lockset.
Might end up saving you some $$ too.
Just my 2c.. Sorry, but I've got no idea on locating the original hardware.
ScottR is offline   Reply With Quote
Old 06-24-2009, 04:19 PM   #3
That thought crossed my mind but with what... bondo, the morticed part seems like it would be hard to replace with a wood block.
Old 06-24-2009, 05:00 PM   #4
Mold!! Let's kill it!
Rewards Points: 2,012
you could redrill the door for a cylindrical entry lock and mount it in a Kwikset 215 modernization kit. Link below. That would close and cover all of the holes.
http://absupply.net/kwikset-215-smal...kit-11468.aspx
Old 06-24-2009, 05:06 PM   #5
thanks that looks like it could work. my challenge has been the door with the lock set side used to have a 9" mortice cover plate on the door edge and a large striker. I will check that part number out for options.
Old 06-25-2009, 07:52 AM   #6
They make a 214 kit that is a little bigger if the 215 doesn't cover.
Old 06-25-2009, 03:48 PM   #7
DIY'r
ScottR's Avatar
Ooh, good call. I didn't even know that those existed.
BTW - I'd get as good a fit as possible with the wood block, fill in around the edge with bondo (or similar), and sand like crazy. Then use hardware with large escutcheons to cover any old holes or whatnot on the sides, if needed.
But the retrofit kit seems muuch easier.
French Drain Solution? Any Help Would Be Great! gregt848 General DIY Discussions 2 08-01-2008 10:16 PM
Replacing mortise locks? chins01 Remodeling 6 07-16-2008 08:14 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
