In Freezer, Will Ice Help If Power Goes Out? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 08-26-2011, 07:34 PM   #1
Rewards Points: 900
In freezer, will ice help if power goes out?
Hi;
We're expecting at least TS winds and lots of rain from Irene on Sunday, so I turned the freezer to its coldest setting. Then I had the idea to put the meat in bags with lots of ice in the freezer.
My thinking is that if the power goes out, the meat packed in ice will stay colder longer than if it were just lying on the freezer shelf.
Also, the ice adds some bulk (heat capacity) to the freezer, thus making it more full, and a full freezer will stay cold longer than a half empty one.
Is this a prudent step, or won't it help any?
FW
Ultrarunner2017 is offline   Reply With Quote
Old 08-26-2011, 07:42 PM   #2
Learning by Doing
Leah Frances's Avatar
Yes. Use potable water in bags or containers. But do it ASAP. Filling your freezer with a bunch of liquid water will raise the temp for a little while. I started adding water to mine on Tuesday.
Also fill your bathtubs and any extra rubbermaid containers you have so you can still flush the toilets.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 08-26-2011, 08:07 PM   #3
biggles's Avatar
Weather channel did a trick and proved that exact point...if you take ZIP lock bags filled half and stack them plastic wonton containers again half filled and let then freze into tomorrow..basically that is how the frig works its the freezer that is the mechanical setting with a damper door for the setting on the frig bottom section.if you limit the trips into the freezer the milk side should stay cold
Old 08-26-2011, 08:15 PM   #4
Rewards Points: 900
Thanks for the advice on filling tubs.
I don't think our bathtubs will actually hold water for long... stopper doesn't work, and don't have a plug that fits well. Maybe another trip to HD tomorrow to pick some up. I don't think rubber drain stoppers will be sold out... ha!
I have a trash barrel set out under where the water will be cascading off the gutter (we didn't have our gutters cleaned recently, but it wasn't my decision to have it done...). That will provide some water for flushing.
I bought several jugs of spring water earlier in the week, so I think we're OK here.
I don't really "expect" an interruption in the city water supply, but 2yrs ago their pump station got hit by lightning, taking out both the POCO and back-up generator power, so we had an outage that lasted for about 6hrs or so.
FW
Old 08-26-2011, 08:34 PM   #5
Learning by Doing
I've got 300 gallons of rain stored (non-potable) and several 16 gallon tubs full of water.
Good luck to all and keep your fingers crossed.
Old 08-26-2011, 08:44 PM   #6
Rewards Points: 900
Yea; I'm hoping that barrel will keep some of the water from getting into the basement...
I have at least one more barrel that I am going to fill from the hose tomorrow and let it sit outside.
FW
Old 08-26-2011, 08:53 PM   #7
Learning by Doing
FW
I actually disconnected my rain barrels today and hooked my gutters up with long extensions. The rain barrels fill up in 10 minutes of hard rain and then overflow.
Old 08-27-2011, 10:27 AM   #8
Rewards Points: 5,336
If you minimize opening the freezer door, the food will stay frozen for at least 2 days.
Ron
B. Franklin 1759
Old 08-27-2011, 11:44 AM   #9
Learning by Doing
yes. Don't even open it at all. I will duct tape mine up.
Old 08-27-2011, 12:32 PM   #10
Experienced
Jackofall1's Avatar
Ice works, but dry-ice works better
Mark
Old 08-27-2011, 12:44 PM   #11
It's called the, " Duct Tape" diet.
The slogan is, "Not just for mouths anymore".
Ron
B. Franklin 1759
Old 08-27-2011, 07:20 PM   #12
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 180
We always have water when the power is out. Water is gravity fed from a water tower. Does it work different on the East coast?
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 08-27-2011, 07:34 PM   #13
Great tips guys~!
Kat38 is offline   Reply With Quote
Old 08-28-2011, 07:38 PM   #14
If you keep ice in your freezer all the time it increases the efficiency.
speedtree is offline   Reply With Quote
Old 08-29-2011, 12:23 PM   #15
I ask the impossible!
Rewards Points: 710
How do ya reckon that water gets up there?
You're still dependent on power operating a pump. Water towers actually are more for maintaining water pressure consistently as demand varies throughout the day.
In a system pressurized by a water tank, the pressure is a function of the height of the water. So the municipality maintains that water height by filling the tank up to an upper limit once it reaches a lower limit, thus allowing the pump to run at one speed and turned on and off as needed.
In a systemp pressurized directly by the pump, the speed of the pump controls the pressure, and modulating pump speed constantly as demand varies is less practical than simply maintaining a reservoir at a certain height of water.
Please do NOT consider any "before" picture of my house as any kind of endorsement of any particular construction method. In fact, you should probably assume that if I post a "before" picture, I am posting it because I am soliciting advice on a proper replacement for one of MANY things done wrong by a previous owner.
WillK is offline   Reply With Quote
Power Save Device capt2 Electrical 52 02-24-2010 06:42 PM
Devices to save on phantom power fetzer85 Electrical 7 12-04-2009 08:03 PM
Recurring Power Oddities - Regular Schedule DamienChaos Electrical 16 10-21-2009 07:45 PM
Wring for Lincoln Power Mig Welder vstoyko Electrical 17 01-15-2009 06:15 PM
safe way to add extension to power cord sil Electrical 7 10-18-2007 09:58 PM
