Framing Rough Opening On Top Of Foundation - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 11-16-2010, 07:19 PM   #1
Framing rough opening on top of foundation
If I'm framing a rough opening (replacing a horrible job) where there is a foundation wall beneath, how is the best way to attach the king and jack studs to the foundation? There is a joist resting where I want to put a king stud. On the other side is just bare concrete block. I know if it was a sill plate I could just toenail it in, but I'm not sure about this.
This is an interior wall, I think it used to be a porch but is now just an interior room. A slab extends beyond the foundation, proving the floor for the room.
Thanks!
Greg
c00rdb is offline   Reply With Quote
Old 11-16-2010, 07:31 PM   #2
DIY Home owner
Not sure exactly what your asking, but if your wanting to nail the king stud to a block wall, use a piece of treated lumber in the size you need, pre drill holes along the length of it, and then set it in place. Using a concrete drill bit, drill through the pre drilled holes into the concrete and nail it in place using concrete nails or screw it in using Tapcon screws. Screws may be a better way to go with concrete block which could crack when forcing a nail through it. Then nail your jack stud in place. That's what I'd do.
Maybe post a pic if possible!
wherm5150 is offline   Reply With Quote
Old 11-17-2010, 08:48 AM   #3
Woodtick
Is the concrete slab the same height as the block? What is the existing framing? Can we get a pic?
ccnvchris is offline   Reply With Quote
New rough opening to basement - spiral staircase benjamincall Building & Construction 8 07-16-2010 05:53 PM
Install Integrity windows over asphalt felt or other rough opening treatments? kooshball Building & Construction 6 12-06-2009 07:34 AM
Framing for drywall under Spiral staircase clemon03 Drywall & Plaster 6 07-17-2009 03:49 PM
Finishing opening for closet Frank_N_Stein Carpentry 11 12-24-2008 08:52 PM
Framing Opening Length captainron19 Carpentry 3 04-01-2006 10:50 AM
