Fractures In The Bath Tub - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-27-2007, 07:30 AM   #1
Fractures in the bath tub
Hi all
My wife had me look at the bath tub in the main bath room and there is some fractures along 1 side. I worked in a boat factory years ago and these type a fractures could be ground out and redone with new I think it was called free coat. Is this possible on a tub? This is a one piece tub so I donít want to tare it out if I can help it.
HAASEMAN2003 is offline   Reply With Quote
Old 03-27-2007, 09:13 AM   #2
Rewards Points: 1,088
A boat has structure though, a bathtub generally doesn't. A steel bathtub generally relies on the strength of the tub itself to contain water. If there's a fracture, the only way you can repair it is by welding it, and you have no access to the underside. A full 50 gallon tub could be holding 400 lbs of water not including the person. It's risky to do anything with this tub.
handy man88 is offline   Reply With Quote
Old 03-27-2007, 09:32 AM   #3
Sorry hand man88 I should of said that it is fiberglass.
Bath Fitter Opinions..?? GoodoleBob Remodeling 31 02-25-2010 09:25 AM
Bath remodel wiring Nhrafan Electrical 14 03-23-2007 05:53 PM
bath floor nailfun Plumbing 5 02-20-2007 10:35 PM
painting filled crack in bath zoodemon Painting 7 10-06-2006 04:15 PM
Unidentifiable pipe/vent in bath Hobiedog Plumbing 1 12-02-2005 05:33 PM
