Found Some Mold, I Think - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-20-2013, 09:48 AM   #1
Rewards Points: 81
found some mold, I think
I'm demoing a 1980s house in MN and I pulled up the carpet and baseboard etc. Lo and behold I found some green spores/mold looking stuff. It's on drywall, studs and steps. I know where the water came from that caused the problem and fixed the leaky pipe. The area was super dry before I found the mold but it's there and it needs to be taken care of. I don't have the budget to hire a contractor to remediate it unless it's completely necessary. The photos show the color is light green, located in a 10 x 6 area on the drywall (easy to cut out and replace as well as the insulation--doubt that there is some present) the first three steps going up the stairs and on one stud that I can see. I can re do the framing and drywall and probably the stairs with some research but will this take care of the problem? Once the mold 'infected' area is disposed of and the source of moisture is removed, will the area need anything else such as bleach or what? Thanks ya'all
found some mold, I think-wp_20131220_002.jpg   found some mold, I think-wp_20131220_003.jpg
lendosky is offline   Reply With Quote
Old 12-20-2013, 11:07 AM   #2
Rewards Points: 1,442
Is that painted or bare paper on the drywall? Looks like it's just on the surface, hard to tell from the pics. Were the materials completely saturated?
mikegp is offline   Reply With Quote
The Following User Says Thank You to mikegp For This Useful Post:
lendosky (12-20-2013)
Old 12-20-2013, 12:18 PM   #3
Rewards Points: 81
In the photos above, the area is unpainted drywall and it looks as if it is just the surface. I got to cutting out some drywall in the area adjacent to the stairs shown and the door jamb within 3' from the stairs and I found what looks like black mold now. Take a look at these pictures please. I am thinking of cutting at least 12" above any visible exterior mold and replacing everything in that area. Good idea? Bad idea? I have a air filter running and negative pressure right now.
found some mold, I think-wp_20131220_004.jpg   found some mold, I think-wp_20131220_005.jpg   found some mold, I think-wp_20131220_006.jpg
Old 12-20-2013, 12:28 PM   #4
Rewards Points: 81
Also, it's been almost a year since someone else lived in this home. It seems that the leak happened over last winter when one of the nearby pipes popped at an elbow. That said, when I turned on the water meter I heard gushing above this area and the water immediately ran to the affected area due to slope. I, of course, fixed everything else--no more leaks. New pipe under the vanity, vanity thrown out. This is freaking me out big time. Thanks for your help.
Old 12-20-2013, 02:06 PM   #5
Mold!! Let's kill it!
Rewards Points: 2,012
You should probably read this thread about mold. No need to freak out. It's not toxic nuclear waste. It's a relatively small infestation that you can easily handle. Read and follow the steps in the thread and you will be fine.
How to control Mold Part 1
The Following 2 Users Say Thank You to Maintenance 6 For This Useful Post:
lendosky (12-20-2013), Windows on Wash (12-20-2013)
Old 12-20-2013, 02:29 PM   #6
Rewards Points: 81
I've already read that post and thought it was useful information. Thanks for helping me reduce my blood pressure by stating it's something I can totally handle myself. It is a small area, not too high, I can rip out, clean, repair and call it.
The Following User Says Thank You to lendosky For This Useful Post:
Maintenance 6 (12-20-2013)
Old 12-20-2013, 02:45 PM   #7
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 46
Black mold
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
rusty baker is online now   Reply With Quote
Old 12-20-2013, 05:58 PM   #8
Rewards Points: 81
I know the mold is media sensation but when it comes to my wife's health I don't want to take any chances. I read online at epa.gov some of the guidelines and all the stuff on here and it seems that I should cut it all out and redo it just to be safe. Since there is no more moisture it would be pretty hard for new mold to grow. When I get to the stair removal etc I will post some pics.
How to - prevent basement mold crazymountain How To Guides 36 07-23-2014 07:02 PM
Mold and spores bluefoxicy Pest Control 9 01-04-2013 09:31 AM
mold on subfllor jigijunk Flooring 11 02-20-2012 02:14 PM
Crawlspace mold repair questions jeep4dog General DIY Discussions 2 11-04-2011 08:03 AM
mold found on registers deerhunter HVAC 0 09-27-2010 08:38 PM
