Found In Alaska - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-10-2010, 05:46 PM   #1
Household Handyman
Rewards Points: 1,408
Found in Alaska
Actually it was not lost. On a recent trip to Fairbanks, AK, my daughter's boyfriend had told me about a rather small, hard-to-find road to get pictures of the Alaska pipeline that normally you don't see. While driving up the mountain on this small road I see this "thing" and just had to stop and look at it closer. Turns out it is an "ore crusher". I did research and found out it was built somewhere between 1840-1660, the only years this company built them in San Francisco, CA. Then I had to sit back and think as to how it came to be out in this obscure area north of Fairbanks, way back then. Pretty impressive feat to get this from CA. to Fox, AK. It's a primarily wooden structure, with cast iron parts and still in great shape actually. Oh Yeah--the flywheel is approximately six feet in diameter. Thanks, David
things found in your walls gregdonovan Off Topic 26 08-06-2011 02:20 PM
Pulled up carpet to put in wood flooring and found 2' plumbing hole in slab. Nightsky Plumbing 1 07-04-2009 08:44 AM
found an old foundation crack in block floor to ceiling flashme18 Building & Construction 14 11-11-2008 10:15 PM
tiling in alaska pelirojapelgrosa Flooring 1 03-01-2007 12:01 AM
