Former Fuel Oil Users Take Note - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-28-2010, 11:32 PM   #1
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
former fuel oil users take note
http://www.1010wins.com/Heating-Oil-...-Motel/6229723
this is why you do not leave a fill pipe intact after you remove your fuel oil tank.
Old 01-29-2010, 03:09 AM   #2
I live 3 towns away
From this poor couple, diesel is a stink that's hard to get
off your hands let alone 75 gallons.
FrankieZee is offline   Reply With Quote
Old 01-29-2010, 07:30 AM   #3
Rewards Points: 5,336
I wonder why the guy stopped pumping at 75 gallons?
Ron
Old 01-29-2010, 09:27 AM   #4
Concrete & Masonry
Rewards Points: 526
Ron
X2, unless it was some kind of budgeted program they were set up on.
Same thing has happened around here a few times, but usually closer to 200 gallons +.
jomama45 is offline   Reply With Quote
Old 01-29-2010, 10:12 AM   #5
Yeah, you always seem to hear about this once a year in the heating season
When I was a kid my dad worked for Gulf Oil, we had automated fill-ups
And as an employee he had a discount on cost
Someone built a house further up the street & they put the same number on their house as ours - 501
They were notified to change it & did not
Oil company goes to fill up their tank...and finds our house 1st
They topped off our tank, old man refused to pay the bill
Best friends dad was a Lt on the police force........
Neighbor changed their house number...probably paid for the oil sent to our house too
Of course in those days it wasn't that much $$
Well...maybe it was...1973 Oil crisis fuel oil was close to $1.80 a gallon
Old 01-29-2010, 11:55 AM   #6
Master General ReEngineer
Bondo's Avatar
Rewards Points: 606
1973 Oil crisis gas was close to $1.80 a gallon
Ayuh,.... Your memory is failing you,...
In 73 gas doubled in my area from .35 to .70 a gallon...
I never paid a Buck a gallon til 79....
Bondo is online now   Reply With Quote
Old 01-29-2010, 12:00 PM   #7
Woops - meant fuel oil
Whatchoo talkin' aboot
Old 01-29-2010, 04:04 PM   #8
nap
You talking to me?
nap's Avatar
I had heard of situations in the past where the delivery guy stopped pumping because he pumped so much and he thought the tank should be full, there must be a problem. yes, that usually relates to a several hundred gallons.
seems like it was a problem in my area at one time. seems like it ended up with a ground contamination problem that took a lot of time, money, and earth removal to repair as it ended up in the ground instead of in the house. Can't remember the spefics of it though.
Old 01-29-2010, 05:37 PM   #9
joed's Avatar
Rewards Points: 11,992
Similar thing happened to guy at work. The water truck pumped 2000 gallons of water into his basement via the sump clean out pipe in back of his house instead of the water tank fill in front of his house.
Fuel savings from burner/nozzle reduction EfficientCanuck HVAC 13 03-01-2009 08:21 PM
Broken Burner Fix mikelbeck HVAC 2 01-16-2009 10:05 PM
Add electric heat so suppliment fuel oil? arichard21 HVAC 12 01-13-2008 11:23 AM
