Forced Hot Water Boiler Help Please - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 10-30-2010, 08:09 PM   #1
Forced hot water boiler help please
I have a forced hot water heater with baseboard radiators. There is no heat going to the house. Checked pilot light is on, bleed the boiler and got some sediment could this be the problem. There is about 12 psi on the thermostat and it's reads about 60 degrees. Could you guys help me with this please.
Rmudder is offline   Reply With Quote
Old 10-30-2010, 08:24 PM   #2
DIY staff
Rewards Points: 7,174
Be patient,there are two or three hydronic heating experts here---While you wait post the maker of the boiler and the number of zones--- and any thing that has been done to the system recently.
I know a bit about hydronic heat but only enough to confuse you.--Mike--
oh'mike is online now   Reply With Quote
Old 10-30-2010, 08:31 PM   #3
Re: Forced hot water boiler help please
This is the boiler it is a peerless. Gas and there is 1 zone.
Old 10-30-2010, 08:43 PM   #4
I really appreciate the help. I just bought this house in September and the problem is in my tenants apartment.
Old 10-30-2010, 09:15 PM   #5
DIY'er
Rewards Points: 35
Could there be any valves that need to be turned on to allow water to flow to the radiators? I don't know much about these seen shows like this old house that has talked about them. But even still if the water at the boiler is hot then to me the problem could be with the boiler.
dirtrider73068 is offline   Reply With Quote
Old 10-30-2010, 10:40 PM   #6
Rewards Points: 5,336
You can't read psi on a thermostat so I'm thinking just answering questions and posting pictures will be the best course of events.
If the house is one zone, either your tenant is not in your building or it's not 1 zone.
It would help if you could clarify where your tenant lives.
With you?
OR
Another location?
If in the same building as you, do you have heat?
Does the tenant have a thermostat?
Do you also have a thermostat?
Post pictures of the boiler that shows piping, pumps, wiring, etc..
Do you know what a circulator pump looks like?
Zone valve?
It could be something simple, so answering questions and postng pictures will help.
Ron
Old 10-30-2010, 10:52 PM   #7
3 apartments in the house 3 boilers. 1 for each apartment. U can tell the psi on the tricator or how ever it's spelled correct? I will post some pics.
Old 10-30-2010, 10:58 PM   #8
There is a thermostat in the apartment. There's 1 in each. And the other apartments have heat.
Old 10-31-2010, 11:38 AM   #9
This boiler is a leaking, neglected wreck. When was the last time it was serviced?
Is the pilot light on?
Is there water in the boiler?
When the thermostat calls for heat, does the boiler come on?
If not, it could be the thermostat or the thermocoupler on the pilot(ifit's not on).
If the pilot is on and the boiler fires up, does the pump turn on?
If the pump turns on and the radiators/baseboard are still cold, you might need to bleed the air out of the system.
Ron
Old 10-31-2010, 11:54 AM   #10
I don't know when the last time it was serviced I just bought the house in September. I jumped the thermostat out and not getting high flame.
Old 10-31-2010, 11:55 AM   #11
The pilot is on. And the boiler is full of water.
Old 10-31-2010, 02:09 PM   #12
There's a gas valve near the boiler. It's a 3 position knob. "ON", "Off" and "Pilot". Where is it positioned? If on "Pilot", move it to "ON".
After that if it doesn't fire, have it serviced.
Some local utilities have a service you can sign up for. They will do a yearly service on the boiler so these issues don't crop up too often.
Ron
Old 10-31-2010, 02:34 PM   #13
It's in the on position. I got it going. I spoke with a heating service. There gonna service all 3 boilers. These boilers need to be serviced every 5 years.
HAPPY HALLOWEE
Old 10-31-2010, 02:53 PM   #14
HAPPY HALLOWEE
Don't keep me in suspense. What was the issue?
Ron
Old 10-31-2010, 03:02 PM   #15
O sorry. There was no power. This was for my 3rd floor tenant and I found the breaker in the 2nd floor electrical panel.
Hot Water Boiler roger kadash Plumbing 3 10-28-2010 11:37 PM
boiler and hot water venting AdamBNYC Plumbing 3 08-26-2010 06:09 PM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 09:42 AM
Outside water boiler shutdown hillardl Plumbing 2 03-20-2009 06:27 PM
Filling a Cast Iron radiator system insulatorpro HVAC 7 10-07-2008 12:31 AM
