Foam Sealant Around Pipes? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 09-20-2013, 09:21 AM   #1
Rewards Points: 1,654
foam sealant around pipes?
In the closet where the hot and cold copper supply pipes come in to meet the water heater, the plumber knocked out two big holes roughly 4" in diameter each. I'd like to patch them back but hard to use joint compound as it just fall into the wall cavity.
Normally I would use some wood backing but pipes are in the way. Can I use those "GREAT STUFF" foam sealant for this? Not sure if those may be flammable around hot water pipes.
If not my last resort is lots of newspapers until I can some resistance to my putty knife.
miamicuse is online now   Reply With Quote
Old 09-20-2013, 11:40 AM   #2
I would be very tempted to use the great stuff foam that is fire rated. Ceartainly I would not use newspapers given your stated concern about flammability. Many times, the structure acts as a fire block, and holes can compromise that capability. Fill the holes with something that can block the spread of flame for the rated period of time.
oberkc is offline   Reply With Quote
Old 09-20-2013, 12:47 PM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,262
Take 2 1x2 pieces of scrap wood long enough to span the hole plus a few inches. Slip into the hole on each side of the pipe, secure with drywall screws thru the front of the wall. Cut a patch to roughly fit the hole, drill the hole for the pipe and cut the patch in half. Install the patch, screwing to the wood scraps you installed. Does not have to be perfect. Tape and mud.
Coastal South Carolina
The Following User Says Thank You to rjniles For This Useful Post:
TheEplumber (09-20-2013)
Old 09-20-2013, 02:26 PM   #4
duplicate.
Old 09-20-2013, 02:26 PM   #5
That's what I normally do to use wood from behind secured with screws from front.
In this case holes are irregular and wood wouldn't fit through and pipe in the way anyways. Going try some crumpled chicken wire stuff through the hole to mud over and see.
Old 09-20-2013, 07:33 PM   #6
A "Handy Husband"
rjniles's Avatar
Open the hole up and square it off.
Old 09-21-2013, 05:13 AM   #7
Rewards Points: 240
hot water pipes don't get hot enough to start anything on fire.
Fix'n it is offline   Reply With Quote
Old 09-21-2013, 07:21 AM   #8
Rewards Points: 6,034
Come on-chicken wire and newspaper??? Cut it square, a couple pieces of 1x and fix it right.
Old 09-21-2013, 08:28 AM   #9
PoleCat's Avatar
Rewards Points: 1,652
I have fixed some pretty big holes by using spray foam. Over fill the void then go find something else to do for a few days. Once it is good and cured you can shave it down to just below the wall surface then mud away.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 09-21-2013, 10:27 AM   #10
Rewards Points: 2,232
some insects are attracted to newspaper, cardboard, etc.
Startingover is offline   Reply With Quote
Scissor trusses, Foam and FG zambo Insulation 2 11-15-2012 06:15 AM
Questions about open cell foam howdihi Building & Construction 2 09-09-2010 09:40 AM
closed cell vs open cell foam insulation amonalisa Building & Construction 1 11-06-2008 09:39 PM
Spray Foam/ Foam Board Hybrid? entropyracer Roofing/Siding 2 09-19-2008 07:12 PM
Leaking around joint of PVC pipes in attic themadcatter HVAC 10 12-18-2007 09:29 AM
