Foam Board Between Joists - General DIY Discussions - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-05-2010, 07:09 PM   #16
Thanks guys!
fubar79 is offline   Reply With Quote
Old 10-05-2010, 08:28 PM   #17
steveel's Avatar
Fu, when you do the rest of the basement, if you research EPS vs XPS foam and make a decision I'd be interested in hearing which you pick and why. That's on my "figure out" list before we start our job.
SteveEl
steveel is offline   Reply With Quote
Old 10-05-2010, 09:38 PM   #18
From what i've read briefly, either work pretty well in a basement. XPS has a bit better R value. And if moisture is a concern at all, go with XPS. But XPS is a bit more $.
I've settled on Roxul for my basement in between the walls.
Adhesive for R MATT foam board captainrichhill Building & Construction 2 05-24-2010 05:40 AM
Floor Joists of different sizes HooKooDooKu Drywall & Plaster 7 02-04-2010 05:43 PM
luxaire/york 33109167000 furnace board replacement check HVAC 18 07-13-2009 10:03 AM
Best way to affix 2" foam board insulation to foundation wall BigJimmy Building & Construction 12 07-21-2008 11:50 AM
Deck Building Question - Installing Ledger Board to Rim Joists Ler0y Jenkins General DIY Discussions 20 05-18-2008 11:05 AM
