Floor Tiles Vs. Wall Tiles - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-06-2008, 10:57 PM   #1
DHandy
Floor tiles vs. wall tiles
I would like to know whats the difference is between floor tiles and wall tiles?
Is it possible to use floor tiles on walls or is that never done?
If you can, would you use a different thin set and grout?
DHandy is offline   Reply With Quote
Old 02-07-2008, 08:21 AM   #2
Rewards Points: 5,336
Floor tiles are made for much more wear than wall tiles. You can put floor tiles on the wall. Don't put wall tiles on the floor. The adhesive/thinset you use is predicated on the surface it's going on. Modified thinset would go on an absorbent surface like plywood and wallboard. Unmodified would be used for a ditra like product which is not absorbent.
Ron
Old 02-07-2008, 09:29 AM   #3
I echo what Ron said...while it might be feasible to use floor tiles on a wall, you would never want to put wall tiles on a floor. One thing I have seen is using floors as ascents on a wall, surrounded by some smaller tiles. I personally thought it looked awful, but that is all in your design....
Last edited by AtlanticWBConst.; 02-14-2008 at 07:13 AM. Reason: Advertising Links Removed
rsmith1024 is offline   Reply With Quote
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
Replacing A Few Tiles On Shower Wall EDENO Remodeling 1 12-11-2006 11:25 AM
mounting 18" tiles to bathroom wall? ako1d Remodeling 3 02-07-2006 04:19 PM
