Floor Insulating - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 11-08-2010, 10:34 AM   #1
Floor insulating
I plan to insulate my home. I live on a beach...bungalow that's built on sand....no concrete foundation. I am replacing the plywood sub-floor and was thinking about insulating underneath the new sub-floor with fiberglass batts. Do i need a moisture barrier? If so, which way to install batts? Paper side up or down? Also , will be installing fiberglass batts in the attic as well. The attic floor to be exact... (between the joists),over the living space. Same question...paper side up or down. As far as the attic "roof", I was just planning on using polyfoam board to add as more insulation. Having a new roof put on, so want to make house as energy efficient as possible. Bungalow is old...from the 20's, and if it helps..i am in the Northeast....thanks
googoo is offline   Reply With Quote
Old 11-08-2010, 06:30 PM   #2
Rewards Points: 1,092
Any kind of vapor barrier typically goes to the warm side of the space, in a heating-load area like the NE. I would personally never use fiberglass under a floor, unless you can ventilate it and keep it dry. It is not very good insulation, btw. Can you get ahold of mineral wool in your area? Closed cell foam, though spendy, may be a good choice for the floor. Blow in (or batts, if you don't want the minor hassle of blowing in insulation) cellulose instead in the lid.
Old 11-08-2010, 06:42 PM   #3
Registered User
Rewards Points: 526
http://www.buildingscience.com/docum...n-crawlspaces/
http://www.buildingscience.com/docum...r-all-climates
And....... welcome to the forum!
Gary
