Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 05-28-2006, 08:30 AM   #1
Floor
had a guy come in to estimate carpet. Under the old carpet, there was plywood, then particle board covered with plastic, some kind of vapor barrier? the room is above a garage that is not heated. I am in Upstate N.Y. cold winters. Was that the reason for the plastic? the particle board was all swelled, assuming it got wet. I have to put new plywood to build up the floor. Should I cover that with plastic after I install the new plywood? thanks
econdave is offline   Reply With Quote
Old 05-28-2006, 11:04 AM   #2
Darylh's Avatar
Floor
They put the plastic in the wrong place. I personly would not of put plastic down. If the garage below is finished and has vapour barrier then all your doing is creating moisture. Use Tar paper on the sub floor then build up with real plywood and then underlay and carpet. Use the higher end underlay to.
If the garage below has not got a finished ceiling then insulate and put the vapour barrier down there that way it will help stop the cold air from rising to your above room. If your not interested in Insulating I would at least put the Vapour barrier on the garage ceiling.
Darylh is offline   Reply With Quote
Old 05-29-2006, 08:01 PM   #3
Floor
so, I put down tar paper on the sub floor, and then the new plywood on top. Now the underlay which is the padding? the garage has a texture ceiling, I dont know what is above the ceiling. I hope this tar paper is suppose to be on the subfloor. Whats the worst case scenario before I lay the carpet?
Old 05-30-2006, 03:53 PM   #4
Floor
was this the right way to do this floor? I hope I am not causing moisture again.
Problem with stain on Laminate Floor Lilypebbles Flooring 4 11-04-2009 05:06 PM
Floor joists for 2nd Floor Addition poptop Building & Construction 4 01-11-2008 08:57 PM
Could installing a furnace to the floor joists cause the floor to slope? JKL HVAC 5 01-03-2007 10:23 PM
Floor joist lower than others drhowarddrfine Flooring 2 04-26-2006 04:25 PM
Help wih floor extremer1519 Flooring 1 12-27-2005 07:33 PM
