Floating Foundation - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-16-2004, 04:41 PM   #1
Guest
Guest
Posts: n/a
floating foundation
can any one tell me how hard is it to form a floating foundation for a steel building 30x36. WHAT WOULD BE THE EASY WAY TO DO THIS.
Old 03-16-2004, 09:08 PM   #2
By floating I assume you mean piers or caissons with void form. Typically it's done with piers placed at a depth to bear on bedrock on which are placed grade beams. Then foundation walls are placed on that and slab inside the walls bearing on the grade beams. Void form depth will depend on what the soils report tells you about how expansive the soils are. I've seen 6" void up to 16" void - so it just depends.
You'll want an engineer to review anything you do. Wouldn't be real good if you didn't get the caissons deep enough and have it heave in the middle of your slab.
hatchet is offline   Reply With Quote
Old 02-27-2009, 12:37 AM   #3
This is also called a "Mat" foundation and used a lot where water tables are high and "pumping"action common. it's also sometimes cheaper than a sprread footing foundation. needs to be designed by an engineer. not quite as simple as doing calcs for a common standard spread footing.
allencd@cox.net is offline   Reply With Quote
Old 02-27-2009, 07:42 AM   #4
Registered User
Termite's Avatar
this is a five year old thread.
Stone foundation for a small shack andrgo Building & Construction 10 09-13-2007 01:49 PM
I need help Re: Poured Slab Foundation - Moved to Plumbing alextina Plumbing 6 04-19-2007 04:35 PM
Permanent Wood Foundation Question opee Building & Construction 2 03-19-2007 09:27 AM
Addition Foundation /Build. advice wannabuild Remodeling 3 12-15-2006 06:28 PM
re-enforcing foundation - southern cal jhb Building & Construction 1 10-02-2006 12:15 AM
