Flattening The Foam - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-30-2009, 01:34 PM   #1
Flattening the foam
For whatever reason, I have a wall in my place covered in the insulation foam ("Great Stuff"). As folks here probably know, this foam dries in unsightly blobs. I would like to get it smooth and flat. For small jobs, I could just cut it with a sharp blade. But cutting with a blade parallel to a wall is tough and getting the entire wall smooth is near impossible. Would a sander do the job? Any other ideas?
sumdumguy is offline   Reply With Quote
Old 12-30-2009, 03:06 PM   #2
Prince George, BC
I've seen people work it with a large hollow rasp. Any solution will probably be messy, but I think a rasp is the most efficient method.
MisterPG is offline   Reply With Quote
Old 12-30-2009, 03:09 PM   #3
Prince George, BC
PS - Here's what I've seen used. Stanley Surform tools. http://images.google.ca/images?q=sta...N&hl=en&tab=wi
Old 12-30-2009, 03:58 PM   #4
Remodeling Contractor
Use an old fine tooth hand saw. This will bend and you can use the two adjoining studs as a guide. Very fast and perfectly flat.
Old 12-30-2009, 06:59 PM   #5
Rewards Points: 5,336
A 6" taping knife should get most of it off. Finish up with sandpaper.
Ron
Old 12-30-2009, 07:51 PM   #6
firehawkmph's Avatar
Rewards Points: 1,822
Ditto on the hand saw.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 12-30-2009, 08:11 PM   #7
I have a 5" flexible saw for trimming dowels flush to work surface may work for you
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
Foam Board on exterior of above grade house Sheldon General DIY Discussions 6 12-08-2009 05:05 PM
fiberglass over rigid foam board in cantilever? KatieAK Building & Construction 3 11-17-2009 08:48 PM
closed cell vs open cell foam insulation amonalisa Building & Construction 1 11-06-2008 10:39 PM
Spray Foam/ Foam Board Hybrid? entropyracer Roofing/Siding 2 09-19-2008 08:12 PM
