Fixing Torn Veneer On Cabinet - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 06-13-2013, 05:44 PM   #1
Rewards Points: 27
Fixing torn veneer on cabinet
We taped some signs to our cabinet when having a party to show which can was recycling and which garbage. Great idea right? Except the tape ripped off a thin layer of the veneer/laminate. Not sure the best way to fix this eyesore. Any ideas?
See lower right corner...
GerardW is offline   Reply With Quote
Old 06-13-2013, 06:11 PM   #2
PoleCat's Avatar
Rewards Points: 1,646
That looks like a printed finish on particle board. It can't be patched with good results. Me? I would cut a piece of 1X4 to width, router some pretty edges on it, stain it then put a towel rack on it and mount it over the blemish.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 06-13-2013, 06:24 PM   #3
Rewards Points: 27
Thanks for the reply PoleCat- you're definitely right about the materials. I agree that a "cover up" may be more practical, but unfortunately the pic doesn't show that there are corresponding marks about 12 inches down from there. Yes I am too thorough and taped the paper at the top and bottom *d'oh*.
So I guess I could get a nice wide piece of wood mounted there to serve the same purpose as the 1x3 but it would be much more... intense.
Old 06-13-2013, 06:32 PM   #4
Ole Wood Worker
BigJim's Avatar
Rewards Points: 398
Make a decorative panel to cover the entire end, maybe 1/4 inch plywood covered to look like you glass doors on the other wall cabinets.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
mj12 (06-16-2013)
Old 06-15-2013, 09:30 PM   #5
If you know what brand and stain you have of your cabinets, order a FEP(finished end panel). /notch for the toekick. Glue on. Done!
mknasa dad is offline   Reply With Quote
Old 06-16-2013, 08:43 PM   #6
Lord of Slums
Rewards Points: 1,974
There is a guy out here that could paint over that. He has this little paint brush set and all these paints. He has gotten very busy these last few years. He paints entire kitchens and does an excellent job at it. " This guy I know" damaged one of his kitchen cabinets with a screw driver in his back pocket, the paint guy came over and matched the existing cabinets perfectly.
mj12 is offline   Reply With Quote
Old 06-18-2013, 01:26 AM   #7
Buy Restor A Finish by Howard. All you do is open the can and put a little on a towel and rub in. Works wonderfully; I use it on everything wood in my house and even on my fake wood kitchen cabinets. I have 3 kids who leave scratches and ring marks and it works amazingly. I bought mine at an antique store and they use it on everything there. I saw it recently on amazon.com and mine is ebony finish but there are other options. Find a finish with a little red in it. Just use soft cloth to apply and rub in, however don't get on you freshly painted walls.
woodlandpatio is offline   Reply With Quote
Old 06-18-2013, 09:08 AM   #8
custom user
Rewards Points: 150
There is no way to repair it apart from covering it up or artistic paint matching, which could be involved depending on faux grain, etc. If it was me I would paint all the cabinets, since the finish is so frail it will get screwed up sooner rather than later.
JasperST is offline   Reply With Quote
Peel and Stick Veneer and Contact Cement GreggG Kitchen & Bath Remodeling 6 02-23-2015 05:30 PM
Need help! Cabinet install gone slightly wrong eemichael83 Carpentry 14 10-26-2010 03:46 PM
Fixing Cabinet Hardware Installed Uneven Nayr Carpentry 13 09-14-2010 08:13 AM
