Fixing My Chainsaw - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 08-18-2010, 02:33 PM   #1
fixing my chainsaw
my grandfather recently gave me his chainsaw. it has seen a lot of use, but it's well maintained. when i first got it, it would start for a second then stall. so i cleaned the air filter and spark plug. now when it runs, the engine boggs down every 3-5 seconds. any ideas what's causing this or how to fix it?
jonnyrebel is offline   Reply With Quote
Old 08-18-2010, 03:13 PM   #2
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
Could need a carb cleaning and/or adjustment
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
Old 08-18-2010, 04:29 PM   #3
Rewards Points: 392
Some 2 strokes have to run on half choke for a bit. After it stalls, try restarting it on half choke; if it starts, let it run and then open the choke.
rustyjames is offline   Reply With Quote
Old 08-19-2010, 10:22 AM   #4
Enough is Enough
H. A. S.'s Avatar
What RJ says, sometimes those little engines require a warm up period, before cutting.
H. A. S. is offline   Reply With Quote
Old 08-19-2010, 12:35 PM   #5
Do work
Rewards Points: 81
I use my chain saw at most twice a year. Sometimes less. I leave gas in it year round. I do, however use stable in the gas. With that said, every 3 to 4 years I need to remove the carb and open it all up. I spray everything with carb cleaner then put it back together. Then it runs like new.
liquidvw is offline   Reply With Quote
Tags
chainsaw , small engine
Why does my chainsaw suck? jpearson311 Tools 30 05-02-2010 09:05 AM
Chainsaw sweetwaters Tools 9 06-08-2009 12:34 AM
Troy Bilt chainsaw cramer Tools 1 06-22-2008 08:53 PM
Gears of War Lancer Chainsaw Spac3Monkey General DIY Discussions 2 06-13-2008 12:45 PM
Fixing a sink - paint removed from the sink deb14905 Painting 2 04-18-2007 11:26 PM
