Fixing A Flooding Garage - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-30-2010, 09:34 PM   #1
Fixing a Flooding Garage
Hi All,
I was wanting to fix a spare garage which is also joined with a bedroom, which I'm about to move into. You see, when it rains hard, both the room I intend to live in, and the garage next to it, flood on one side, the side which you could call the back of the garage. Basically a big pool of water comes in and soaks the one side of the room, too, creating mildew, a big mess! I asked one of my friends about this, and he told me that to fix it, you would, basically make a frame out of wood in front of the leaky side, then pour concrete into it, let it harden, and take away the frame, then there'd be a block of concrete to keep the water out.
I know almost nothing at all about home improvement, can someone help me? For example, I have a hard time imagining how to even make the wooden frame that was mentioned to pour into. Are there any easier, or, even more important, more effective ways to do this? I'd really like it so that no water floods in at all, but also, I'm on a budget.
Thanks,
Jim
Earthworm Jim is offline   Reply With Quote
Old 04-30-2010, 11:00 PM   #2
Rewards Points: 1,910
The suggested solution isn't making sense to me. Let's start with where is the water coming in? Is the ground around the building sloped away from the building so that rain flows away from the building? Do gutters and downspouts discharge rain water near the building or 6 to 10 feet away. Are the garage and bedroom at grade level or below grade level?
Old 05-01-2010, 09:04 PM   #3
Household Handyman
Rewards Points: 1,408
It's been said before on these forums: Picture(s) are worth a thousand words, if you can post them. David
Old 05-01-2010, 10:01 PM   #4
Rewards Points: 5,336
The solution to your problem depends on the reason the water is getting into the building. You need to post a series of pictures of the exterior of the buildings.
Looking at the area around this section should give you some basic understanding of the cause. Ground slope and water from gutters and leaders would be a start. In order to get the best pictures it would help if you had some understanding of the contributing factors.
Ron
Old 05-03-2010, 09:20 AM   #5
Coconut Pete's paella!
CoconutPete's Avatar
Rewards Points: 504
Water seeps into my garage too when it rains a lot. The problem seems to be that after years of buildup - the ground on the outside of the foundation is slightly higher than the concrete line of the foundation. When I get time I'm going to dig it down and hopefully that'l take care of the problem.
The whole thing about the wooden frame and concrete etc. seems like a weird solution if it's possible to lower the ground outside.
CoconutPete is offline   Reply With Quote
The 12-Gauge Garage Jack Olsen Project Showcase 28 07-08-2012 11:21 PM
Basement flooding problem found problem just need help fixing it. tayous Flooring 2 03-30-2010 09:55 AM
Garage Insulation DIYguy2000 Building & Construction 2 12-09-2009 08:41 AM
Raising up my garage jimmyfloyd Building & Construction 5 09-17-2009 11:39 PM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 03:57 PM
