Fixing Drive/walkway Issue - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 09-28-2009, 11:12 AM   #1
fixing drive/walkway issue
Hello everyone- I'm new to the forum.
My house (Circa 1984) was built with a tiled driveway and walk. Unfortunately, the thin tile (approx. L 7" W 4" D .5") applied to the concrete driveway with thin set mortar has begun to come up. Many pieces have split in half...or cracked off near any edges of the drive or walk way. I'm told that the initial installer explained that the tiles were too thin to put down for this application, but the owner didn't listen.
I also know that there are several areas of the concrete drive and walkway- are either majorly cracked or broken...obviously causing the tiles to pop off in that section.
I'm curious as to what the best- most economical course of action would be to not only correct this issue, but also update the look of the drive/walkway.
My thoughts are to;
OPTION 1:
Jack hammer up all the tiles AND the thin set mortar on top of the concrete. Next, fix any concrete issues that are apparent. Next lay down some type of Mastic application that would allow the new tiles to 'move' under pressure.
OPTION 2:
Resurface the existing concrete using either a stamped application or something similar.
Any thoughts and/or advice on the matter would be GREATLY appreciated.
Roger
puma69 is offline   Reply With Quote
Old 09-28-2009, 05:15 PM   #2
Rewards Points: 5,336
I have never seen tiles on a driveway. Can you post some pictures?
Any other houses in the area have this?
Ron
Old 09-28-2009, 07:11 PM   #3
I don't have any images, but they are ceramic tiles applied to the surface of a concrete drive/walkway slab with a thin set of mortar.
Old 09-28-2009, 09:26 PM   #4
Where do you live?
Ron
Old 09-29-2009, 09:57 AM   #5
Master General ReEngineer
Bondo's Avatar
Rewards Points: 354
Ayuh,... How about Option #3,...
Rip out all that's there,+ have a new Blacktop driveway installed...
A ceramic tiled driveway Must be pretty Funny lookin'....
Old 09-29-2009, 10:39 AM   #6
Newbie Bill
Rewards Points: 518
Sorry, I have no advice.
But I'd love to see a picture of that. I wonder if it gets slippery when wet.
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is offline   Reply With Quote
fixing drive/walkway issue puma69 Building & Construction 2 11-02-2009 05:05 AM
AC condensate issue cleddy HVAC 1 08-02-2009 10:26 PM
Interlock Paver Issue cbadrik Landscaping & Lawn Care 2 07-27-2009 08:29 PM
HELP - with my breaker box. Interesting issue. LordX Electrical 75 02-23-2009 04:14 PM
Cable issue or wiring issue? Duchey Electrical 57 12-15-2008 02:34 PM
