Fixing Basement - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 09-23-2010, 11:07 AM   #1
Rewards Points: 56
Fixing basement
My finished basement got destroyed from a broken pipe which flooded out the basement. Threw out the rugs and drywall....can anyone offer advice on how to clean up the basement floor and walls to kill and prevent mold from forming before I put up new drywall and level the floor with cement? Thanks.
diyGK is offline   Reply With Quote
Old 09-27-2010, 12:57 AM   #2
Rewards Points: 956
google water water everywhere link to a thisoldhouse article
federer is offline   Reply With Quote
Old 09-27-2010, 02:34 PM   #3
Your best bet is to get some industrial fans to help dry things out. Even a dehumidifier will help get the moisture out. You can rent all of these at a rental place. Leave them on for a few days and it will help dry things out. Whatever doesn't dry in a few days is not worth keeping, throw it out.
Hope that helps.
Cheers
17Irish17 is offline   Reply With Quote
Old 09-27-2010, 04:34 PM   #4
concretemasonry's Avatar
Rewards Points: 2,570
If you have fiberglass that has been exposed to moisture, take it out and replace the insulation (different type hopefully). It will not dry out in place with just some fans blowing on it. It has to be removed and aerated by movement the cause drying. Since you have it out, you might as well put in something better and you wall have a change to treat most of the framing to give it a chance.
I have inspected homes that had repairs made 3 months earlier that had to be torn out.
Dick
concretemasonry is online now   Reply With Quote
Cutting out a concrete basement floor jeffhoward001 Building & Construction 21 01-17-2012 09:51 PM
Thoughts and ideas basement finishing and HVAC creamaster HVAC 1 03-10-2010 08:46 PM
basement subpanel suggestions/advice desired ScottsName Electrical 4 02-26-2009 07:38 PM
A few Q's on Finishing My Basement - Is there a FAQ on this? ossrocks Remodeling 6 01-07-2009 01:21 PM
Sub Basement Walkout - Please Help pgs_28 Building & Construction 11 08-12-2007 10:55 PM
