Fix Gaps In Stairs - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 05-24-2008, 02:23 PM   #1
Fix gaps in stairs
Several years ago we had a contractor remove the carpet from the stairs and replace the treads with oak treads. The risers were left and we painted them. At the time the stairs seemed fine altho the contractor did leave some small gaps between the stair and stringer. Now it looks terrible. Any ideas how we can repair these gaps?
Thanks, jamowa
Fix gaps in stairs-stair-gap1-diy.jpg   Fix gaps in stairs-stair-gap2-diy.jpg   Fix gaps in stairs-stair-gap3-diy.jpg
jamowa is offline   Reply With Quote
Old 05-24-2008, 02:40 PM   #2
Jay123's Avatar
As far as code goes you want a minimum of 3/4" overhang (tread nose to riser front) and a max of 1 1/4" so...
you may be able to put a 1/4" skin (plywood, mdf, etc) over the existing riser and caulk and paint.
J
Jay123 is offline   Reply With Quote
Old 05-24-2008, 07:01 PM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
That overhangs on the steps do not look sufficient. As stated, they should be about 1 " to 1-1/4".
Regardless, the best method of repair (what will look the best)...would be replacement of the riser finish boards. Measure and cut to fit properly.
- Build Well -
Old 05-24-2008, 07:07 PM   #4
Cheap fix would be wood filler, but not the best fix for sure.
raam is offline   Reply With Quote
Old 05-24-2008, 07:16 PM   #5
Jay123's Avatar
The only thing with that raam is that it tends to crack in wider applications like this (especially with the movement of stairs...think of the force of all the steps on it.)
....but, it would be a very inexpensive "try".
J
Old 05-24-2008, 07:20 PM   #6
J
I thought about that too, but my conclusion was the same: It will crack...
- Build Well -
Old 05-24-2008, 07:42 PM   #7
Jay123's Avatar
Yuuup...but at least they won't be thinking...I should have tried the "cheap" fix. As you well know, sometimes doing it the hard (or wrong) way makes us smarter the next time.
Been there, done that, have the t-shirt...ad nauseum...
J
Old 05-24-2008, 10:30 PM   #8
J
Hmm, ok how about silicone caulk ?? LOL
Old 05-24-2008, 10:37 PM   #9
Go ahead and try it. It is an easier attempt. The worst thing that could happen is that you will not like the result, and then you can go with Plan B: replace the riser boards, or Plan C: Install some kind of shallow width molding into the area....
Plan D: Fill in the areas with Ready Patch & sand. Then apply caulking over it, to keep it from crumbling, Last - prime and paint.
Last: Follow Plan E: Don't hire anymore hacks that think they can do finished carpentry...
Good Luck.
- Build Well -
Old 05-24-2008, 11:39 PM   #10
Rewards Points: 6,652
There is no way to fix it properly, without tearing the whole mess apart, and doing it correctly.
Changing from carpet stairs to wood stairs DIY_user Remodeling 16 07-29-2010 08:16 PM
Concrete stairs jmat1980 Building & Construction 2 04-19-2008 12:45 AM
baseboard trim gaps on stairs beppygirl General DIY Discussions 8 02-24-2008 02:31 PM
Prefab or custom stairs? brokie General DIY Discussions 1 01-21-2008 08:11 PM
