#1 |
fitting a replacement bath exhaust in a bigger hole
Hi, i have a cheap Nutone bath exhaust in my bathroom (60 sq. ft. w/8 ft. ceiling) and i don't think it's working that well. After the 4 of us are done taking showers the ceiling is soaked! It's a small 70 cfm nutone from HD. Anyway the housing is around 15" x 8 1/2". I've been trying to locate an exhaust 100 cfm or more to fit in that opening and not having much luck for under $200.
So my newb question of the day is this. How do i patch about 5" of the length of the hole with drywall? There is no stud above. I only need to fill in about 5" x 8 1/2" to make way for a new square bath exhaust. And the bathroom was just repainted too so i really didn't want to get into cutting a big square to the studs. |
#2 |
Use a piece of 1/2" plywood. Make the plywood longer then the opening so you can screw in 4 drywall screws. Then just cut a piece of drywall and screw it to the plywood. Tape, compound and paint.
Ron |
#3 |
fitting a replacement bath exhaust in a bigger hole |
#4 |
Plywood will probably be stronger in your situation but I have also used thiese clips before and love them, cheap and easy. http://www.prest-on.com/Scripts/prod...p?idcategory=3
| Display Modes | |
| Replacement impeller and clip for Heil exhaust inducer blower | iixeb | HVAC | 2 | 01-09-2009 09:36 PM |
| How to fix a BIGGER hole in a cast iron pipe?! | skatestoked2000 | Plumbing | 3 | 12-08-2008 01:12 PM |
| Drywall - hole for outlet bigger than faceplate | slinku2020 | Drywall & Plaster | 6 | 06-30-2008 02:10 PM |
| Complex challenge with bath exhaust fan - need help with solution! | Honest Bill | Electrical | 6 | 11-02-2007 03:52 PM |
| bath exhaust fan questions | rtoni | HVAC | 3 | 10-25-2007 04:46 AM |
