-   -   fitting a replacement bath exhaust in a bigger hole (http://www.diychatroom.com/f2/fitting-replacement-bath-exhaust-bigger-hole-36870/)
mayhem69 01-26-2009 12:39 PM
Hi, i have a cheap Nutone bath exhaust in my bathroom (60 sq. ft. w/8 ft. ceiling) and i don't think it's working that well. After the 4 of us are done taking showers the ceiling is soaked! It's a small 70 cfm nutone from HD. Anyway the housing is around 15" x 8 1/2". I've been trying to locate an exhaust 100 cfm or more to fit in that opening and not having much luck for under $200.
So my newb question of the day is this. How do i patch about 5" of the length of the hole with drywall? There is no stud above. I only need to fill in about 5" x 8 1/2" to make way for a new square bath exhaust.
And the bathroom was just repainted too so i really didn't want to get into cutting a big square to the studs.
Ron6519 01-26-2009 01:08 PM
Use a piece of 1/2" plywood. Make the plywood longer then the opening so you can screw in 4 drywall screws. Then just cut a piece of drywall and screw it to the plywood. Tape, compound and paint.
Ron
mayhem69 01-26-2009 02:51 PM
Ron
great idea, thanks for that wonderful advice!
ponch37300 01-26-2009 05:04 PM
Plywood will probably be stronger in your situation but I have also used thiese clips before and love them, cheap and easy. http://www.prest-on.com/Scripts/prod...p?idcategory=3
