Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 01-15-2013, 03:41 PM   #1
Which is first concrete paint or floor leveling compound?
I was going to paint my concrete basement floor with a moisture barrier paint. but I was also going to pour some self levelling concrete to fill in a few bad spots.
Which should I do first?
thanks
hswerdfe is offline   Reply With Quote
Old 01-15-2013, 05:52 PM   #2
paper hanger and painter
chrisn's Avatar
thanks
I would think that would be first.
The Following User Says Thank You to chrisn For This Useful Post:
hswerdfe (01-15-2013)
Old 01-16-2013, 07:31 AM   #3
PoleCat's Avatar
If that water proof paint is cement based don't expect it to survive long on the floor. It is very brittle and will fracture easily.
PoleCat is offline   Reply With Quote
Old 01-16-2013, 07:35 AM   #4
Super Moderator
Yikes----Self leveling compound is to soft for use as a finished floor---it will be all scraped and gouged in no time----
mae-ling (01-16-2013)
Old 01-16-2013, 08:01 AM   #5
Have you considered using an epoxy compound such as is used on garage floors?? Also, one of the companies that does spray-on bedliners for trucks (Line-X I think) has products for use on concrete floors and patios.
How to paint a outside concrete patio and what paint to use Chariot8 Painting 7 12-03-2012 02:21 PM
Interior concrete paint removal help needef julieingranbury Flooring 0 10-24-2011 12:34 AM
Bamboo on modified concrete pad jhanson Flooring 0 10-08-2011 12:58 PM
Is it ok to paint concrete floor in winter... dbldee20 Painting 2 02-06-2009 02:06 PM
Concrete cement wall leaks and paint BobFar Building & Construction 7 04-16-2007 06:22 PM
