Fireplace Suggestions? - General DIY Discussions - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-02-2013, 01:36 PM   #16
Special User
Rewards Points: 1,230
Originally Posted by jpc View Post
My centrol ac/heat is ran off electric, and fireplace is wood burning.
All right, now we're talking.
So, wood fireplace. Two problems. Number one, most of the heat goes up the chimney. Solution for that is a fireplace insert. Inserts have heat exchanger tubes above the firebox, so that heat otherwise wasted in the smoke can be recovered and sent into the room via a fan.
Second problem: intake air. Fire needs oxygen; a fireplace pulls air from the room it's in. This makes the house negatively pressurized, so you start sucking cold air from outside from every crack and creating cold drafts. Solution for that is a fireplace insert that has a separate outside air intake. It has a sealed combustion chamber so house air that's already been heated stays in the house. Sadly, not all inserts have outside air intakes, so you have to do your homework when selecting yours.
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is offline   Reply With Quote
Old 04-02-2013, 08:00 PM   #17
Rewards Points: 236
without pic/s and/or a model #. you guys are just speculating.
Fix'n it is offline   Reply With Quote
Old 04-16-2013, 02:06 PM   #18
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
Our house was built in the 70's. It had an inefficient wood burning fireplace. In the winter (when we were not burning it) it would always be at least 10 degrees cooler in that area.
Two years ago we had a wood burning insert installed. It cut our heating bill dramatically. And now we can heat the whole house with just the fireplace if we want.
One caveat. I would suggest you hire a professional to install it. If you are considering doing this DIY, check with your homeowners insurance. If something goes south and you have a fire, it could be an issue.
Need opinions on tearing out old fireplace Dwillems Building & Construction 9 09-06-2011 11:37 AM
New project: removal of old fireplace-replace with a new fireplace! MrShadetree0222 Building & Construction 14 10-16-2008 06:12 PM
Possible to build direct-vent fireplace? DIYerself General DIY Discussions 3 12-22-2007 10:07 PM
Removing a Fireplace - suggestions? BigFloyd Building & Construction 1 08-03-2006 05:01 PM
